d16a6 questions
Old Apr 23, 2009 | 08:31 PM
foowitdaredek's Avatar
Default d16a6 questions
my friend recently bought a 1990 honda civic hatchback and the old d15 was running like ****. so he told his mechanic about it and the guy who sold it to him happens to be a mechanic so the mechanic said he would put a d16a6, now his questions are would he have to use the a6 ecu or is the d15 ecu fine i also noticed that there was a hole in the back of the block which i think would be for the vtec solenoid....oh and hes also using the d15 intake manifold.
Old Apr 23, 2009 | 08:40 PM
ryanevansoh's Avatar
Default Re: d16a6 questions
if you are using the old dpfi manifold, then you can keep your ecu and dude, vtec has to deal with the head so that hole is not the vtec solenoid, plus a d16a6 is non-vtec
Old Apr 23, 2009 | 08:47 PM
GlassHeadlights's Avatar
I would recommend converting it to MPFI if you have the whole A6 motor (Intake manifold and all)
It would run better and you would get more power.
To convert it to MPFI keep the DX harness then add the wires mneeded for the A6, add the resistor box and put in a PM6 ECU.
If you're going to run it with the D15B2 intake manifold, I would consider putting in the B2 camshaft to make it run like stock.
Old Apr 23, 2009 | 09:06 PM
thanks for clearing that up...wasnt sure what it was....also i have a z6 intake manifold layin around would that bolt right up?
Old Apr 23, 2009 | 09:10 PM
im sure it would, but you would need to change to mpfi
Old Apr 23, 2009 | 09:17 PM
It would bolt right up but you do need to do the MPFI swap.
Old Apr 23, 2009 | 09:27 PM
heres that hole i was telling you guys about
Old Apr 23, 2009 | 09:33 PM
93formula's Avatar
if its a thru hole, its for a carbed fuel pump, normally found on a jdm sohc zc but the head could have been off of one at one point in its life, fab up a plate and block it off.
Old Apr 23, 2009 | 09:35 PM
It's just part of the casting. Nothing to worry about unless you can see right through into the head.
Old Apr 23, 2009 | 09:47 PM
puertoricanboy90's Avatar
X2. There is a sealed port like that on my A6 head. Nothing to worry about and it is not usable for v-tec.
Willianog15
Dec 22, 2016 06:59 PM
91accord25
Nov 16, 2012 08:28 AM
boostinh2x
Mar 14, 2009 08:54 PM
204E-EF6
Dec 28, 2006 03:25 PM
SOUNDSFAST
Sep 11, 2003 03:12 PM
