Vss problem
Like tha title says vss problem i've tried everythimg from changeing out speed sensors to fuses to cleaning the plusg that goes to it. my vss was working the other day and then it stop no odometer no nothing
PLZZZ HELP ME
PLZZZ HELP ME
It looks like your O2 sensor is bad or disconnected.
For the VSS, check whether fuse 24 is blown and then disconnect the VSS connector (see diagram) and, with the key turned to ON(II), you should measure 12V or 5V at the Yel/Blu or Yel/Wht terminals, respectively.
With the key turned OFF, you should have continuity to ground on the Blk terminal.
