h23a1 head with F22B block
Old Apr 23, 2009 | 07:02 PM
Silencer RPMs's Avatar
Default h23a1 head with F22B block
Okay I've been looking online and can only find info for a h23 head with f23 block. So I was thinking of using all my h23 stuff including, water pump, head gasket, and so on. I wanted to change my piston rings so should I just buy rings for a F22B1 block? Oh and please don't tell me to just get a h22 or something like that. thanks
Old Apr 23, 2009 | 08:51 PM
boostedmonkey's Avatar
Default Re: h23a1 head with F22B block
I was contemplating on doing the H23/F23 hybrid. Low end torque and stroke from the F and greater tuning capabilities with the H. I was gonna go the H22/F23 route for the vtec aspect of it, but i'm not sure anymore. Plus, the H23 looks just like my B20. Same black crinkle paint on both. It would be a great motor to turbo. The F23 bottom end is pretty stout.
Old Apr 23, 2009 | 10:48 PM
ttt
Old Apr 24, 2009 | 04:45 AM
95greenlude's Avatar
Originally Posted by boostedmonkey
Low end torque and stroke from the F...
you do realize the stroke from the f22 is the exact same as the H23.....
Old Apr 24, 2009 | 07:35 AM
Bangher4$'s Avatar
did honda balance the f22 crank from factory? i was told that the h23 was not balanced.
Old Apr 24, 2009 | 07:38 AM
mattsnooz's Avatar
I belive from what I've read here on H-T that vtec model h22 cranks were balanced to allow higher reving.
The h23 crank is not balanced from what I've been told also. Knowing this, thats why I assume the f22 isn't balanced.
Old Apr 24, 2009 | 08:30 AM
PirateMcFred's Avatar
The H23 head can be installed on any Accord F-series block.
H22/23 waterpumps will not work on an F-Series blocks.
Use an F-series head gasket, not H-series.
The H23 crank is not cast and is drill balanced.
Old Apr 24, 2009 | 10:49 AM
Yeah, i was referring to the F23 bottom end.
Old Apr 24, 2009 | 10:57 AM
Sam1am26's Avatar
Wow. I haven't been on HT in a while. I still have my complete H23 Head/F23 block sitting in my garage. Things been collecting dust. Finally putting it in the civic next month...
Old Apr 24, 2009 | 11:37 AM
Hurry up, dood. I wanna see pics. Please????????????????
Old Apr 24, 2009 | 03:24 PM
Long time no see Sam, want some cams for that thing? I won't be needing mine for much longer. :Linky:
Old Apr 24, 2009 | 05:23 PM
ok so what head gasket should I buy for? a F22b1? And what about the piston rings that I want to buy? Anywhere you suggest i buy this?
Old Apr 24, 2009 | 11:27 PM
Even on the F20B Accord Euro motor?
Old Apr 25, 2009 | 12:17 AM
so what head gasket do I run? The F22B head gasket does not fit and the closest thing is the h23 gasket.
Old Apr 25, 2009 | 11:22 AM
Monkey, that's harder and might require some epoxy to prevent an oil leak but it will bolt on.
Silencer. Use a HG that matches the make/model of the block.
Old Apr 25, 2009 | 11:54 AM
piratemcfred the headgasket that matches the make/model of the block doesn't match up with the head. Its not even close.
Old Apr 25, 2009 | 11:57 AM
S2Integra's Avatar
all you need is an F20C head, if it can be done of course
Old Apr 25, 2009 | 04:04 PM
I know WTF the gaskets look like. I know that they're different.
Just use an F-series SOHC gasket and put a little hondabond in one part of the H23A1 head and you'll be fine.
If you don't want to do it that way then get a custom gasket made or weld up that one recessin the H23 head so it will clamp the gasket on that one corner.
Old Apr 25, 2009 | 05:54 PM
oh ok. So I won't have to cut the F series gasket so it fits perfectly with the cylinder head right? and one more question piratemcfred, do I use the h23 timing belt and oil pump? because I saw that you said that I use a F series water pump.
Old May 11, 2009 | 10:52 PM
camshafted's Avatar
will this motor drop right into the h23 mounts? im doing the same exact swapa s we speak.
Old May 15, 2009 | 07:19 AM
flyrod's Avatar
No kidding! Nice to see you back here, good luck on the swap!
pkolaboy
Feb 19, 2008 06:37 PM
Nikoli
May 4, 2004 06:50 AM
stinger
Oct 2, 2003 01:02 PM
DLB1994
Sep 23, 2001 07:26 PM
DLB1994
Sep 23, 2001 05:07 PM
