Rear disc brake conversion
Old Apr 23, 2009 | 04:55 PM
FearTheH's Avatar
Icon2 Rear disc brake conversion
So ive got a 99 civic si, before you go sayin "Si's already have disc brakes jackass" heres what happened, i busted my trailing arm the other day so i picked up a used one from a junkyard off of a 96 EX, obviously this has drum brakes on it. while removing brake components to do the ole switch-a-roo, The Torx head bolts holding the brake assembly onto the trailing arm rounded due to being very rusty and just all around garbage. with their given location i cant exactly get to them using vice grips, or any other normal means of extraction... should i just drill them out and retap the holes on the assembly, aka the part that looks like knuckles, or is there another means I should try first before destroying this thing??? Thanks in advance for your help!
Old Apr 23, 2009 | 06:20 PM
FearTheH's Avatar
Default Re: Rear disc brake conversion
no one???
Old Apr 23, 2009 | 06:37 PM
freakasis's Avatar
so your gonna put drums on the back because you broke a trailing arm?
Old Apr 23, 2009 | 06:39 PM
FearTheH's Avatar
negative, im trying to swap my si disc assembly onto the new trailing arm(off an EX with drum brake) and the stupid rusty torx head bolts that hold it to the trailing arm are rounded out, im debating on drilling them out...just wanted to see if anyone had a pre-last resort method to try to get them out without drilling
Old Apr 23, 2009 | 06:40 PM
98civdx's Avatar
Master Detailer
why you do that i dont know...
just get some knock er loose from home depot or somewhere. let it sit and the try with a throx bit. not pilers.
Old Apr 23, 2009 | 06:45 PM
FearTheH's Avatar
okay im going to say it again...the torx head bit ROUNDED them out due to them being rusty and brittle. im trying to find an alternative to getting them out by drilling them. read entire post next time
Old Apr 23, 2009 | 06:54 PM
freakasis's Avatar
except the trailing arms are differant from drum to disk. or at least the honda part numbers are differant.
Old Apr 23, 2009 | 06:59 PM
FearTheH's Avatar
the trailing arms arent different, the only difference is the shaft that the wheel bearing goes on, and also the "bracket" that holds the brake assembly to the trailing arm... which is all interchangeable, and the bolts that hold that "bracket" are the ones im trying to remove so i can put all my Si disc stuff on the new trailing arm
Old Apr 23, 2009 | 07:03 PM
98civdx's Avatar
Master Detailer
opps i read the whole thing, im not a great reader and sometimes miss things.
yea drill them out a re tap
Old Apr 23, 2009 | 07:12 PM
FearTheH's Avatar
lol its all good man... i believe thats what im gunna do, ive lost all my daylight and have no garage time to bust out the work lights! w00t! i hate trailing arms! lol thanks fellaz
Old Apr 23, 2009 | 07:15 PM
Murk 'EM's Avatar
either get an "easy out" or cut a "line" if you will the head of the bolt so you can use a flat head (if you can get that in there)
Old Apr 23, 2009 | 07:16 PM
Murk 'EM's Avatar
and use alot of pb blaster and or a tourch
Old Apr 23, 2009 | 07:17 PM
freakasis's Avatar
gotcha, becuse hondas part number includes all that stuff.
Old Apr 23, 2009 | 07:18 PM
FearTheH's Avatar
i can get a screwdriver in there easy, its getting the dremel in the approx 1 1/2" hole to access the bolts and make the slot haha... and ive used a whole can of pb blaster, great stuff but has somehow screwed me on this! lol. guess ill be drillin them out i really wanted to avoid doing that but seems like my only option now
Old Apr 23, 2009 | 07:20 PM
FearTheH's Avatar
yep, and id hate to see how much theyd want for the trailing arm/brake assembly, i paid 30 bucks for this one.. not too bad considering its prolly atleast 300 at honda. but yeah im definitely wishin i woulda paid more to avoid all this stripping down and swapping parts...ERRRRRR!!!!!
VegasEg8
27
May 16, 2014 11:38 PM
JDMCRX
Suspension & Brakes
Sep 11, 2012 06:49 AM
egb18c5
Northeast (Sales)
May 28, 2007 07:39 PM
EsCo_EsCo
Oct 10, 2005 07:54 PM
