after market scat rods d16z6 rod bearing color
Tryin 2 figure out how to find out. Wut color code oem bearings I would use for the scat rods. Or the best way 2 find out
you have to measure it. Each OEM CRANKS and Mains measure differently. Aftermarket and even OEM rods measure differently also. There's no such thing as a 1 size that would fit all when it comes to bearings. You have to measure to get the right color and clearance.
do you still have your stock bearings if you have no way to measure your crank use your stock bearings as a mock up and Plastigage it (check the clearances) and go from there on what bearings to order .
surfinjoe911
Feb 15, 2008 07:25 AM
