charging system problems
Old Apr 23, 2009 | 03:00 PM
1997civicex's Avatar
New User
Icon2 charging system problems
i have a 1997 civic ex. i just replaced the alternator and checked the volts right after i changed it. and it was running 14 volts into the battery. now i only have 11.45 and dropping. what could be causing this problem? And i finally got the obd port to work. and pulled these codes.
1.VSS
2.o2 sensor
3.air fuel metering malfunction
Old Apr 23, 2009 | 03:23 PM
Former User's Avatar
Default Re: charging system problems
Check whether fuse 15 is blown under the dash.
Old Apr 23, 2009 | 04:48 PM
New User
I checked the fuse its fine. what now?
Old Apr 23, 2009 | 04:52 PM
What are the specific CEL codes? How did you ensure that fuse 15 is fine?
RedneckRicer
20
Apr 9, 2014 08:19 PM
Civic Racer X 7
13
Jun 1, 2011 04:56 AM
SmoothCTR
Apr 7, 2011 10:35 AM
justdoinme23
Aug 18, 2010 12:55 PM
Luiz_aka29
12
Aug 15, 2009 08:56 PM
