d16y7 in ef four door
Old Apr 23, 2009 | 02:58 PM
Boostn B20's Avatar
Default d16y7 in ef four door
im bout to buy a 4 dour. dude sellin it says he swapped it wit a y7. he says theres 4 wires he does not kno where to connect inside onto the ecu. does anybody kno anything about this. 4 wires that do not have connect to the ecu when swapping in an obd2 motor.
Old Apr 23, 2009 | 03:41 PM
es.roadster's Avatar
Default Re: d16y7 in ef four door
i really can't help you out but i'll throw you some ideas. it could be one of the following or mismatched: o2 sensor ( 4wire ) or the injectors.
but if you're new to the obdX conversion, in my opinion, don't bother with it.
you're way better off buying another car and build it for yourself. good luck though
Old Apr 23, 2009 | 03:52 PM
Boostn B20's Avatar
yea. im pretty sure it's the injectors. n i wud. but the car is for cheap.
Old Apr 23, 2009 | 05:13 PM
auto CRX's Avatar
idk an ob2 motor is a wireing challenge into an ef
Old Apr 23, 2009 | 05:54 PM
~sp33~'s Avatar
EFB055
Does the car run?
Old Apr 24, 2009 | 03:35 AM
Boostn B20's Avatar
no
Old Apr 24, 2009 | 06:16 AM
mjfubar101's Avatar
If your smart you just convert the whole thing down a notch, to make it all easier.
Old Apr 24, 2009 | 06:35 AM
4drEF's Avatar
Keyboard Humorist
You are going to have to get a meter to do continuity tests to trace out where those wires go.
What ECU do you have in there?
It's very common to run an OBD2 motor as OBD1 and I'm hoping that's what you have going on in there.
Old Apr 24, 2009 | 06:36 AM
mjfubar101's Avatar
Yes OBD1 is wayyyyy better
Old Apr 24, 2009 | 11:14 PM
~sp33~'s Avatar
EFB055
Originally Posted by Boostn B20
no
I would really want to steer clear then. There could be a whole host of problems that your not going to be aware of until the car is in your possession.
Wh0 Iz UNREAL07
Nov 24, 2008 06:21 PM
530guy
Apr 24, 2007 06:41 AM
y0iTsDEENOSE
Sep 1, 2005 01:32 PM
gato5254
May 3, 2005 02:49 PM
red civic standard
Jan 16, 2003 08:17 AM
