Vss?
Old Apr 23, 2009 | 01:25 PM
mixwell's Avatar
Default Vss?
tach is working in my ek. but my speedo is not.
b16a2, and si gauge in a 97 hatch.
anyone have a part number?
Old Apr 23, 2009 | 01:32 PM
mixwell's Avatar
Default Re: Vss?
part no. 78410-S04-901 & 78410-S04-902
that's for what would be the stock motor. will this work for my b16?
Old Apr 23, 2009 | 01:34 PM
Former User's Avatar
Default Re: Vss?
Is the CEL ON? Do the tripmeter or odometer work? Is fuse 15 blown?
Old Apr 23, 2009 | 01:36 PM
mixwell's Avatar
Default Re: Vss?
happened right before i got home, and there was a cel. lemme go run my car for like ten minutes to see if it comes back up (the cel), and pull the code to make sure. good thing i have my volt meter.
Old Apr 23, 2009 | 01:44 PM
raidacaipo's Avatar
Default Re: Vss?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/vss-problem-2537650/
Old Apr 23, 2009 | 01:57 PM
mixwell's Avatar
Default Re: Vss?
^^^ was actually reading that earlier.
too many cars at my house, i will have to wait for a few hours before i can check. i park my ek in the garage b/c of thieves. the cel, if it comes back on, won't light unless i'm driving. (off to find a spare wire to make a jumper.)
the fuse? i have to figure out how to use the voltmeter. (instead of asking HT i'll page a friend since its his.)
sorry, i'm new to fixing hondas, especially anything electronic, although i did replace pads and rotors on my brother's accord yesterday.
Old May 8, 2009 | 12:14 AM
mixwell's Avatar
Default Re: Vss?
update:
it was the VSS. so happen right after the VSS was fixed, the alternator died along with the battery.
there was a crimp in the wire going to the fuel pump, causing voltages to be off and battery not charging correctly and maybe causing my alternator to crap out and (one more) my VSS to die.
it was either what i typed above or my car was in really bad shape. >.<
rossthab022
16
Mar 22, 2012 10:11 AM
Superide
18
Aug 30, 2011 12:45 PM
cbaber
Oct 14, 2009 10:47 AM
domenic
Sep 22, 2009 06:32 PM
ntrider
15
May 29, 2005 01:53 AM
