ls swap question..help
just to make things clear. im thinking about picking up 96 ls motor for a hell of a good price 750 complete to be exact. im planning on swaping it into my si hatch which is a 93. and i know that from 92-95 is obd1. since this motor im planning to pick up is a 96, i would an obd1 to obdII harness correct?
I used my D16 harness(the LS harness was ****ed up)and had to swap Injector Clips, and swap over to the LS Alternator plug, Extended wires for O2 Sensor and IACV.
Then grab a OBD1 P75 ECU, Unplug the P28 and plug in the P75.
My swap went werid but I ain't explaining that in your thread(Details if you want)
No...convert the engine to OBD1. Use OBD1 LS Dizzy, OBD1 B-Series Alternator(or you can modify the OBD2 Alt. but I dont know the details) and use the D16 Engine Harness and modify to work or use the LS Harness.
