Question on Skunk2 cams
Well Im pretty much building my jdm gsr and have a couple questions, i have already bought ctr pistons with a skunk2 valvetrain along with a skunk2 intake manifold, type r tranny and was wondering if skunk2 stage2 pro series cams would be ideal for a dd civic? oh and was wondering what the compression would be like with ctr pistons and if 93octane would still be able to run the car thinking compression might be to high no clue. In advance thanks.
Why did you purchase CTR pistons if you do not know how it will run on your motor?
FYI, P30 pistons have made more power than CTR's pistons, in the builds I have experience with.
As for your question, if you can find a good tuner (hint, DFE-ENT is right down the road from you) Pro2's will be fine. If you are tuning yourself and are a novice, or your tuner has never dealt with Pro2's before, your results will probably be bad.
OP, Do yourself a favor and ditch the CTR Pistons. Pawn them off on someone else (preferrably with a B16 head) and use something that will make power for you (i.e. P30 or P73-00).
JC not a day goes by in AM where somebody doesnt ask if their CTR's will work with XX cam combination or with a GSR head, LOL.... its like these noobs see the PCT and are drawn to it senselessly like a fly drawn to a bug zapper.
"Wizzerd...wit dat ballin' comprizession an dem Skizzunk2 Prizzos, my VTAK gon' be hittin' mad tyte y0!"
Makes you wanna
well i bought the pistons off a buddy for hundred bucks brand new in the box thought it was a pretty good buy and had a set of p72 rods laying around. So instead you guys recommend p30's. Tru i think i kno were your getting at here instead i should probably run some itr's instead.itr's have less compression then the ctr's which is roughly mid to low 12's.
The CTR's have a heigher compression height which has been known to cause piston to head contact easily when used with the P72 head where the piston meets the quench area in the combustion chamber. This espeacially becomes a concern if the block has been decked.
I'd sell them and go with ITR's, my $.02
The resulting Compression Ratio is NOT the problem. Go ahead and use them. Maybe you'll see what the problem ACTUALLY is.
Sweet planning on selling them asap then. Just wondering what power gains will i be seeing with itr pistons on a three angle valve job and ported polished head along with the skunk2 stage 2 pro series cams.thanks for the advice guys appreciate it.
I'm sure theirs quite a few B18C motor's running Pro1's & 2's, check it out...
LOL, thanks Brice!
Don't expect a novice builder to get the power out of these parts that an experienced builder & head porter can get.
Bro...if it were me.....I'd pack up my engine sh*t, and take a drive to see DonF in Jacksonville. He's one of the best builders for Hondas you'll be able to find. You're SO lucky he's within a 3 hr drive of you. When you talk to him, have your mind ready and remember EVERYTHING he tells you....and count yourself lucky IF he agrees to work on your project. BUT...DO YOUR HOMEWORK BEFORE YOU GO. He has a "NO STUPID SH*T" policy.
I'm willing to bet the build would benefit from a different header. Your build just shows that the DC CAN support some HP.
