Good deal on a tranny, what should I do?
Old Apr 23, 2009 | 06:42 AM
Mugen Type R's Avatar
Default Good deal on a tranny, what should I do?
Hey guys, My tranny has been lacking good synchros for the past 3 years and since I had the money this year I wanted to rebuild it. But the problem is the down time. So I was thinking having seen this ITR tranny for sale cheap, perhaps I should get it. It is high mileage, owner says synchro 5-R is bad, but rest is ok says the guy. On my tranny, all my synchros are bad except the 4th gear, but I still have to change em all as it comes with the 3rd gear synchro, which is shot.
So should I buy the tranny 500$ and rebuild it slowly through out the summer while using mine, then switch them out and rebuild mine and resale it? This implies 1 tranny install 2 rebuilds.
Install his 500$ tranny without rebuild since it's most likely in better shape than mine even though the 5th gear is bad(so is mine) and rebuild mine so I could keep the original tranny in the car and resale his after the job, rebuilt or not, and get the same money I paid for it. This implies 2 tranny installs this summer and 1 or 2 rebuilts depending and the sale of one tranny.
Should I avoid buying his and just rebuild mine and risk some down time?
Wait it out an extra summer and rebuild mine at the end and ride another summer with shitty synchros double clutching and rev matching as I am actually doing?
I need advice guys, I could get this tranny rebuilt up and running for a total of roughly 1000-1100$ including the seals synchros bearings given about 600$ for the rebuild parts (is that enough?). How much does a rebuild typically cost in parts? I searched alot of threads, but I didnt come accross one where honda parts are clearly listed and compiled for a one call order to Len
Thanks for the input guys!
Old Apr 23, 2009 | 07:54 AM
HondaRcB's Avatar
Default Re: Good deal on a tranny, what should I do?
I wouldn't get rid of your original tranny, as the VIN will no longer match your car, which will hurt the resale value. I would either tolerate some down time, or buy and rebuild the other tranny and still keep your original, though I know that's not the cheapest option.
Old Apr 23, 2009 | 10:37 AM
THE LORD OF CHAOS's Avatar
i wouldnt buy that other messed up tranny. just bite the bullet and accept some down time to get it fixed.
if u cant afford the down time then look for a gsr or b16 tranny. u can usually find a good one for 400-600 dollars.
Old Apr 23, 2009 | 11:00 AM
Thanks for your input so far, anyone else ?
Old Apr 23, 2009 | 11:21 AM
96ej8MR's Avatar
I say buy it rebuild it put it in then rebuild yours and put it back in later down the road, but do not sell the matching vin one
Old Apr 23, 2009 | 11:37 AM
Reyes's Avatar
why not just buy all the parts for your rebuild now, while your still driving your car. and once you have everything, then pull yours and rebuild it, really if you plan it right you should have much down time at all.
Old Apr 23, 2009 | 11:58 AM
Thrule01's Avatar
a) sit with the downtime while current one is rebuilt
b) source a b16,gsr, ls to use for mean times while stock one being rebuilt and then sell it once finished
Old Apr 23, 2009 | 12:19 PM
racebum's Avatar
there's a guy on ebay who pops up with new in the box from honda ITR trannies for $1300, i just bought one myself. for the price they are a great deal and you can sell your broken tranny for around $500. just the LSD is worth 300. i would spend the extra 800 on a new one. and yes. the dealer can switch your vin plate to the new transmission. most body shops probably could as well. this also could help the resale since you would have paperwork of a new oem part.
Old Apr 23, 2009 | 02:41 PM
is that shiped? last i saw a tranny on ebay shipping was 400
Old Apr 23, 2009 | 03:00 PM
How is this non OEM kit from synchrotech do for a rebuild at 349$
does anyone have experience with it?
The stealership is costing me the price of a new tranny to rebuild mine so I dunno bout that route... any input on this kit or another?
Old Apr 23, 2009 | 03:47 PM
Topshot's Avatar
Ha! Just finished installing a tranny that I bought from him!
Old Apr 23, 2009 | 03:54 PM
how much did it run you shipped?
Old Apr 23, 2009 | 08:01 PM
racebum's Avatar
shipping was $85 for both of us. comes brand new in the honda crate.
Old Apr 24, 2009 | 01:13 AM
stiness101's Avatar
The parts im sure are probably fine. Syncrotech was gearspeed. The only thing is that most of the time its not just the syncro's that are bad but also the syncro sleeve gets chewed up. You can try and file it down so its smooth and doesn't bind on the hub and try and make the grooves pointed again with a file or just replace them all together, thats why the oem kit includes a new hub and ring along with the syncro's.
Old Apr 24, 2009 | 06:22 AM
Yeah well, they sell synchro sleeves as well on the site, might be able to get a complete rebuild package or something. I'm sure I have every set of sleeves chewed, all my gears are in bad shape but they all go in though.
Thanks for your input guys... So far plan is to source a LS tranny (which I had laying around) and pull the R tranny, check it and order the needed parts and fix it as soon as I can after that... that way I'll have no downtime and still get the take my caR out
Thanks for the help everyone!
FLCivic
Oct 22, 2010 05:48 AM
boostinnc
Transmission & Drivetrain
Jan 2, 2010 01:37 PM
importtuner07
Jun 22, 2006 08:44 PM
dantheman203
Oct 29, 2004 12:41 PM
JimmyT89
Mar 23, 2004 07:08 PM
