fog light relay/fuse box question.
Old Apr 22, 2009 | 08:34 PM
kojack_0's Avatar
Default fog light relay/fuse box question.
what relay would i use?
im trying to replicate this wiring diagram.
and does anyone know whats the location of the gray and red plugs into an ef fuse box?
ive searched this already. and all ive found is people offering replica harnesses to op's threads. im trying to make one myself and not buy it. thanks in advance.
Old Apr 23, 2009 | 05:47 AM
kojack_0's Avatar
Default Re: fog light relay/fuse box question.
anyone?
Old Apr 23, 2009 | 05:59 AM
crx_si-r's Avatar
what kind of switch are you planning on using? because i personally have not seen any 4 wire switches like you have illustrated.
Old Apr 23, 2009 | 06:22 AM
kojack_0's Avatar
the jdm oem switch.
it has white, white/blue, and black wires.
the illustration shows switch in and lights on as one wire spliced. so i would assume its only one wire.
do the egs have 4 wire?
Old Apr 23, 2009 | 09:21 AM
crx_si-r's Avatar
but your diagram won't work as you have it set up for 4 wires and the own switch is only 3 wire for front facing fogs and 5 wire for rear fogs, I know because I have both switches, check out my sig below
eternity-
13
May 20, 2015 09:18 AM
hardrock2401
Oct 13, 2013 06:50 PM
tallguy21
Lighting
Jul 19, 2013 08:23 AM
MattNYC
Sep 12, 2011 03:34 PM
the_dxB16
Oct 17, 2008 08:06 AM
