fog light relay/fuse box question.
what relay would i use?
im trying to replicate this wiring diagram.
and does anyone know whats the location of the gray and red plugs into an ef fuse box?
ive searched this already. and all ive found is people offering replica harnesses to op's threads. im trying to make one myself and not buy it. thanks in advance.
Re: fog light relay/fuse box question.
what kind of switch are you planning on using? because i personally have not seen any 4 wire switches like you have illustrated.
the jdm oem switch.
it has white, white/blue, and black wires.
the illustration shows switch in and lights on as one wire spliced. so i would assume its only one wire.
do the egs have 4 wire?
but your diagram won't work as you have it set up for 4 wires and the own switch is only 3 wire for front facing fogs and 5 wire for rear fogs, I know because I have both switches, check out my sig below
eternity-
13
05-20-2015 09:18 AM
