what head gasket should i use ?
Old Apr 22, 2009 | 07:57 PM
Joeski99Si's Avatar
Default what head gasket should i use ?
I have a turbo b16 with stock internals, i just blew the head gasket. just wondering what head gasket i should buy ? I'v heard from a couple people to stick with the oem honda gasket, but i kind of would like to go with a thicker head gasket.
ANY SUGGESTIONS ?
Old Apr 22, 2009 | 08:14 PM
Joeski99Si's Avatar
Default Re: what head gasket should i use ?
anyone ?
i tryed searching in FAQ for a answer but came up with nothing
Old Apr 22, 2009 | 09:27 PM
ke98248's Avatar
No -- the OEM head gasket is fine although some oem headgaskets blow- i believe your b16 should be ok... You need to get the motor machined and some ARp head studs to clamp your **** together
Old Apr 22, 2009 | 09:33 PM
98civdx's Avatar
Master Detailer
oem should be ok,
i have also heard good things about cometic
Old Apr 22, 2009 | 09:51 PM
:TEAL:'s Avatar
oem is good i like cometics never did me wrong
Old Apr 22, 2009 | 09:57 PM
G2_Fella's Avatar
i had a head gasket blown on me for the first time last year. i've used oem and it runs perfectly fine. no problems so far.
Joeski99Si
Apr 23, 2009 05:24 AM
racin_jayson
May 18, 2007 07:37 PM
jarven093
Feb 27, 2007 03:23 PM
B18cHatch06
Jan 18, 2006 07:23 PM
