Lighting HID/Xenon kits, Retrofits and Associated Topics
HID bulb size for eg fog ????
Old Apr 22, 2009 | 07:05 PM
vtec19's Avatar
Default HID bulb size for eg fog ????
Hi guys .. i got a pair of yellow eg fogs but they just arent bright enough ... was wondering if i could install HIDS in them and if so how ...
Old Apr 25, 2009 | 03:08 PM
6footmidget's Avatar
Default Re: HID bulb size for eg fog ????
theres a kit somewhere in the marketplace, its like 100 bucks
Old Apr 25, 2009 | 03:37 PM
Sway_eg6's Avatar
i bought the same fog kit..i have ? dose anyone know why my fuse from my my fog lights keeps burning out the day i put them on they worked fine the next day they won't turn on and kept burning my fuses??Help!!!
Old Apr 27, 2009 | 09:42 PM
HIDXTRA's Avatar
Try a higher amp fuse. Fuse burn out normally is caused by a lower amp fuse than spec. What amp of the fuse you replaced?
Old Apr 29, 2009 | 03:47 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Worst advice ever!!! DO NOT use a higher fuse rating than what is specified! That can cause a FIRE!
If each 55W H3 bulb has its own fuse, don't go higher than a 10A fuse. If both use a single fuse, don't go any higher than a 15A fuse.
Fuse burn out is normally caused by a short somewhere, NOT because of using a lower-amp fuse than specified. And switching to a higher one can very easily cause an electrical fire.
Old Apr 30, 2009 | 05:47 AM
Lasky's Avatar
^^I Agree with that DO NOT use a higher amperage fuse than is required you will most likely cause a fire somewhere in that wiring
but to help you with your question I would double check all the wiring and make sure there is no bare wire showing or touching any other metal or bare wires.
Old Apr 30, 2009 | 06:03 AM
Lasky's Avatar
and for the HID's all you have to do is find the bulb size thats run in the fogs, im not sure what size it is off the top of my head, but then just buy a plug and play kit that is for that bulb size, put it in and shizzammm HID fogs
hope this helps man
Old Apr 30, 2009 | 06:36 PM
Sway_eg6's Avatar
the fog lights came with a 15a fuse
Old Apr 30, 2009 | 06:37 PM
Sway_eg6's Avatar
oh ok thanks for the help you guys!
Old Apr 30, 2009 | 10:32 PM
HIDXTRA's Avatar
Please read my post again. I didn't tell him to upgrade the fuse amp, but simply suggested to check the fuse and fuse normally burn out due to wrong fuse used than on spec.
jdmturboitr
Sep 9, 2007 05:40 AM
kuja396
25
Mar 6, 2006 08:29 PM
EJ1_203
Apr 13, 2005 11:46 PM
AF-b16a1
Jun 22, 2004 10:31 PM
AutoXsi2000
Sep 30, 2002 07:38 PM
