throttle response wheel/cam
tried searching, but got nothing.
does anyone make different throttle cam/wheels for H-series engines?
if you dont know what im talking about then heres one for my friends 944
http://cgi.ebay.com/ebaymotors/PORSC...Q5fAccessories
i want a new one because mine is rusty and looks like hell next to everything else. and because i actually would prefer if my throttle wasent so "snappy" and more of a exponential throttle to make launching easier.
my engine revs so fast after the light weight flywheel, A/C eliminate, and overdrive pullys, and i'm also using a stg 3 exedy clutch, so even for an experienced 5-speed driver first gear is like a hair trigger between spinning tires, or stalling.
if they dont make one, i may consider designing one and making one, so let me know if anyone else is intrested.
I've never seen one for Hondas. But taking one of the standard diameter and off-setting the pivot would provide a progressive opening of the throttle. I've thought about it a lot for the horrible throttle control on my lopey nonVTEC Hybrid's TB but never got around to making one.
I would just suggest launch practice.
This could be controlled through tuning I believe. You could adjust the TPS output and how its picked up by the ecu I would think. Any ideas anybody?
'Weapon R' makes one for increasing throttle response and they come in bling anodized colors. Maybe you could modify one of those?....
hey thanks, i didnt think of searching for "throttle rotor"
but the only problem is that this increases throttle response, i actually want to slightly decrease my throttle response, perhaps its time to start some fabricating...
blackhatch13
17
Mar 31, 2003 05:45 AM
