Is there a way to make the gas pedal react faster???
is there any way to make the gas peday more sensitive??????
I just want to know if there is a way to make the car respond faster during take off!!!
Re: Is there a way to make the gas pedal react faster??? (blackhatch13)
Re: Is there a way to make the gas pedal react faster??? (Crosser)
throttle cam (throttle response cam) if they make them for Hondacuras? Not sure, only seen 'em before for the 8v 944s (I am surely showing my global automotive I.Q. with this I am sure).
Re: Is there a way to make the gas pedal react faster??? (phat-S)
Re: Is there a way to make the gas pedal react faster??? (martini)
I also recomend (with the installation of a new throttle cam) you go ahead and replace the throttle linkage bushings with solid core stiffeners. That should help take out some of the play.
On a side note, how about installing some anti lag compound onto the pedal itself.. less actual "pedal force" will be needed to get it to move all the way to the floor, efficiently.
Uhmm, I was/am being serious. Where's Apocolypse944CupSpeedFreak? Maybe he knows what I am talking about.
Actually, I think Weapon R really might make throttle cams... Phat-S and martini are right on the money.
Re: Is there a way to make the gas pedal react faster??? (WRXRacer111)
edit:
http://www.dragonintakes.com/throttle/
http://www.importstudio.bigstep.com/generic.html?pid=21
[Modified by FritzInTN, 5:27 PM 3/28/2003]
Re: Is there a way to make the gas pedal react faster??? (.RJ)
I didnt make the topic.... i just provided an answer. Maybe he has short feet and can't push the pedal all the way down...
Re: Is there a way to make the gas pedal react faster??? (BryanSprinkel)
Tighten your throttle cable.
Squidwerd
08-15-2013 01:30 AM
