zc swap need help plz!
Old Apr 22, 2009 | 02:49 PM
minime-dom's Avatar
Default zc swap need help plz!
hey i got this motor from a friend and and i got it in and all that but when i start it sounds like it just wants to stall ,its throwing to codes 9, and 21 and i dont know what they are plz help
Old Apr 22, 2009 | 03:14 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: zc swap need help plz!
SOHC ZC or DOHC ZC? OBD0 or OBD1? VTEC or non-VTEC?
Old Apr 22, 2009 | 04:53 PM
minime-dom's Avatar
its a 1987 zc dohc non vtec obd0 , i found out that i had a vtec cumputer so i switched it to a pm6 and i still have the code 9 and i dont know wut that is
Old Apr 22, 2009 | 05:47 PM
sixgunsound's Avatar
Needs a new dizzy
Old Apr 22, 2009 | 06:58 PM
minime-dom's Avatar
i just bought it on criagslist down philly it is new still in the box to
Old Apr 23, 2009 | 06:13 AM
jlicrx's Avatar
code 9 is the cylinder sensor - on the OBD0 DOHC ZC or D16A1, the cylinder sensor is not in the distributor - it is on the end of the exhaust camshaft - usually, a code 9 is either incorrect camshaft timing or a problem with the cylinder sensor wiring - the cylinder sensor itself going bad would be extremely rare
Old Apr 23, 2009 | 06:46 AM
minime-dom's Avatar
i looked at the wiring and every thing is good , so do u think i should go buy a crank sensor?
Old Apr 23, 2009 | 06:59 AM
~sp33~'s Avatar
EFB055
Have you checked the timing?
Old Apr 23, 2009 | 07:20 AM
minime-dom's Avatar
yeah i looked at the timming and every thing is right
Old Apr 23, 2009 | 07:42 AM
jlicrx's Avatar
i would try switching the 2 wires at the cylinder sensor
Old Apr 23, 2009 | 08:31 AM
minime-dom's Avatar
still throws the same code 9 again
Old Apr 23, 2009 | 09:05 AM
minime-dom's Avatar
wait do u mean cutting the 2 wires then putting them to the other wires??
DA9kid
Jun 30, 2011 06:22 AM
minime-dom
Apr 30, 2009 12:19 PM
dohczcrex
Jun 10, 2007 07:20 AM
El pimp chulo
Sep 25, 2006 02:08 PM
