Radiator fan not working in ek.
Old Apr 22, 2009 | 01:35 PM
Whatever's Avatar
Default Radiator fan not working in ek.
Alright so my Radiator fan will not work at all. I put in a new radiator fan switch and then pulled the thermostat housing out, turned the key to the "on" position and then put a heat guy on the fan switch to see if the fan kicked on. I had the heat gun setting at 1300 degrees and the fan never kicked on. I now realize why the guy I bought it from wasn't running a thermostat in the car when I bought it. Of course he neglected to tell me that and I found out about it in the winter when my car wouldn't put out any heat.
Anyway, what can I do to make this work? Or what else can I check out? This car is driving me nuts...
Old Apr 22, 2009 | 01:46 PM
raidacaipo's Avatar
Default Re: Radiator fan not working in ek.
take off the fan plug wire sensor from the fan sensor. Take a paper click and stick it between the fan plug wire sensor on the 2 pins.. your fan should start spinning.. if it doesn't then there's a problem with your radiator fan or the wires..
Old Apr 23, 2009 | 06:11 AM
Whatever's Avatar
The jumper worked and the fan fired right up. The Fan Switch is brand new so I doubt that is the problem. What else would cause it not to work?
Old Apr 23, 2009 | 06:16 AM
Former User's Avatar
The test indicates that the "new" fan switch doesn't work.
Old Apr 23, 2009 | 06:23 AM
Whatever's Avatar
Well that sucks... Either that or I didn't get it hot enough with the heat gun.
Old Apr 23, 2009 | 08:30 AM
EL Vap133's Avatar
Turn the car on, forget using the heat gun. Let the car run for about 20 mins or until the fan hits. If they needle gets close to the red area and the fan has not turned on then shut it off right away.
Old Apr 23, 2009 | 08:34 AM
BuiltCivic99's Avatar
ya lol...man its ur switch...the test showed u that it was bad. cmon wut did u think u were doing that test for?
Old Apr 23, 2009 | 08:36 AM
EL Vap133's Avatar
On my Civic, I had a problem with the fan kicking in at times. I had replaced the fan switch but it turned out the wiring had a short. After the wiring was fixed the fam kicked in each and every time.
Old Apr 23, 2009 | 09:49 AM
Whatever's Avatar
I'm waiting for a new fitting to come in for the oil return line for the turbo. Until I get that I can't put oil in the car and fire it up so I will have to wait till tomorrow evening to test it out...
joelro28
Feb 22, 2014 12:43 PM
maverick32
Jun 17, 2009 10:49 PM
dudeomega2000
Jan 6, 2008 09:51 PM
