Tranny Swap... What to "Replace"
Old Apr 22, 2009 | 01:02 PM
aalb1's Avatar
Default Tranny Swap... What to "Replace"
I'm doing a tranny swap with a tranny that has been sitting for 3 years... it rotates freely the release bearing seems fine. But any idea on what seals or anything else I should replace before the swap? Thanks in advance
Old Apr 22, 2009 | 01:05 PM
sp00ledbseries's Avatar
Default Re: Tranny Swap... What to "Replace"
Does the input shaft have any play to it. If so change the bearing
Old Apr 22, 2009 | 03:23 PM
batallic's Avatar
rear main seal also, its requires removing the tranny which yur doin anyways
Old Apr 22, 2009 | 03:27 PM
fallbacdun's Avatar
just to be safe take it to a shop and have them open it up!
Old Apr 22, 2009 | 04:29 PM
90Rexx's Avatar
just put axle seals in it and put it in.... theres nothing else easily serviceable if you have never taken apart a tranny. id suggest using new honda mtf though.... stuff is like liquid gold its great.
Old Apr 22, 2009 | 05:15 PM
robfrmny21's Avatar
stick a screw driver through the hole that the holds the linkagage to the trans, shift the tranny make sure its moves freely with no sticking or jamming if it does you might have to crack her open
HexMoon
Transmission & Drivetrain
May 9, 2017 09:08 AM
silentbeatz
18
May 24, 2006 03:03 PM
norm13
Jan 23, 2006 03:22 PM
