Removing rear ITR wing--what plug does everyone use?
Old Aug 15, 2002 | 09:27 PM
Todd00's Avatar
I said I don't want a title!
Default Removing rear ITR wing--what plug does everyone use?
I don't want a permanent rear wing removal, so I'm looking for what kind of plugs everyone uses when they take the wing off. Am I lucky enough that Honda makes a part that will perfectly fit?
Old Aug 16, 2002 | 04:31 AM
CarbonfiberR's Avatar
Default Re: Removing rear ITR wing--what plug does everyone use? (Todd00)
I just went the easy way and got yellow vinyl from a local sticker maker and cut little circles that were just bigger than the holes.
Old Aug 16, 2002 | 04:33 AM
Willard's Avatar
the plugs (4) off of a EG Civic where a upper strut brace would bolt (if they came with one).
remove paint and install.
Old Aug 16, 2002 | 05:15 AM
1GreyTeg's Avatar
No problem, and Willard is correct. this is the part #: 91601-SR3-000
Do me one favor though, if and when you remove the bolts could you please try to figure out the torque of the bolts. I will be hitting Limerock in November and will be re-installing my wing and forgot to mark down the torque specs for the bolts.
If you ever need the rubber gasket to re-install the wing, contact Wings West, they have the gasket for their version of the wing that they produce for Comptech. I asked to purchase one gasket kit and they just sent it to me free of charge. Needless to say with everything import related being so expensive I was pretty impressed.
Hope I helped ya, and hope you can help me.
If you have ANY questions about the removal just ask. Mines been off for almost a year now.
A.
[Modified by 1GreyTeg, 6:20 AM 8/16/2002]
Old Aug 16, 2002 | 05:16 AM
BDiddy's Avatar
Default Re: Removing rear ITR wing--what plug does everyone use? (1GreyTeg)
i used new bolts and a new wing
Old Aug 16, 2002 | 05:42 AM
MikeD's Avatar
New User
I just left the holes open. They are fully painted so I don't see anything corroding, and they just run over the water drain channel anyway (not over the sealed part of the trunk). It is not noticeable from other cars except SUV's, and who cares about them anyhow?
Mike
Old Aug 16, 2002 | 06:59 AM
Todd00's Avatar
All good info guys--thanks.
Old Dec 29, 2004 | 12:01 AM
Dc2 Powered's Avatar
real sorry to bring this thread back but.. if i do this.. are the plugs removeable or will it break and i would have to buy new ones if i ever plan on taking them off
edit: also are they these plugs?
Old Dec 29, 2004 | 12:34 AM
.water's Avatar
Default Re: Removing rear ITR wing--what plug does everyone use? (Dc2 Powered)
my friend have those kind of thing on Civic trunk..i think u have to snap the bottom part ..lol no big deal tho...but there is other kind that when u talking them off u can press both side (bottom) it will pop up..
Old Dec 29, 2004 | 12:52 AM
B2FiNiTY's Avatar
If those are the oem ones, they are rubber and you can reuse them a billion times.
Old Dec 29, 2004 | 01:22 AM
:jdmshmaydm:'s Avatar
Default Re: Removing rear ITR wing--what plug does everyone use? (B2FiNiTY)
Use FastCaps. They're for cabinets or whatever. I have white ones so when I go wingless you can't tell unless you look close. They blend with CW. However you could always marker them with black or whatever color to make them discrete.
Old Dec 29, 2004 | 04:23 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc2 Powered &raquo;</TD></TR><TR><TD CLASS="quote">edit: also are they these plugs?</TD></TR></TABLE>
those are not the pulgs I spoke of.... but they look like they will work.
the ones I spoke of are removable without issue.
Old Dec 29, 2004 | 07:10 AM
uzabatty's Avatar
Default Re: Removing rear ITR wing--what plug does everyone use? (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">but they look like they will work.</TD></TR></TABLE>
good pics u found, ugly as hell but hopefully it's a temp thing
but they look easy to put on/remove
like I said, hopefully it's a temp thing unless ur car is black
Old Dec 29, 2004 | 09:38 AM
Seedc2's Avatar
1GreyTeg: i checked with the helms manual and didnt find torque specs for the itr wing.
part #: 91601-SR3-000 does anyone have a picture of this part #?
Old Dec 29, 2004 | 09:56 AM
1GreyTeg's Avatar
Default Re: Removing rear ITR wing--what plug does everyone use? (sim shadeee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sim shadeee &raquo;</TD></TR><TR><TD CLASS="quote">1GreyTeg: i checked with the helms manual and didnt find torque specs for the itr wing.
It looks similar to the plug above but it doesn't have the stem, just a harder plastic cap sorta that fits the holes better than those softer rubber plugs above, that I've also had and got from a local auto parts store but replaced with the Honda plugs for better and more secure fitment.
I've since installed the wing permenantly and tossed the plugs.
Old Dec 30, 2004 | 04:16 AM
Boosthead's Avatar
I searched and Majestic Honda has them for $1.35 ea
http://www.hondaautomotivepart...3-000
Old Dec 30, 2004 | 06:12 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sim shadeee &raquo;</TD></TR><TR><TD CLASS="quote">1GreyTeg: i checked with the helms manual and didnt find torque specs for the itr wing. </TD></TR></TABLE>
<FONT COLOR="red">That's because you're not supposed to take it off!!</FONT>
(Just kidding. You can do what you want, of course.)
Old Dec 30, 2004 | 04:25 PM
i went to honda today and the guy said just go to ace and pick up some plugs their cheap and you wont have to order it..so i was wondering what size? etc
Old Dec 30, 2004 | 08:09 PM
Reid's Avatar
Global Moderator
Default Re: (Dc2 Powered)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc2 Powered &raquo;</TD></TR><TR><TD CLASS="quote">i went to honda today and the guy said just go to ace and pick up some plugs their cheap and you wont have to order it..so i was wondering what size? etc</TD></TR></TABLE>
Are you THAT lazy?
Measure the holes, then you will know which size to use.
Old Dec 30, 2004 | 08:19 PM
Chris F's Avatar
Default Re: (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">
Are you THAT lazy?
Measure the holes, then you will know which size to use. </TD></TR></TABLE>
These are the right size plugs. Call Napa, I think they have them.
http://www.albinoblacksheep.com/flash/plugs.php
Old Dec 30, 2004 | 09:00 PM
Wht-Blk dc2's Avatar
leave the wing ...
Old Dec 30, 2004 | 09:53 PM
Seedc2's Avatar
Default Re: (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.albinoblacksheep.com/flash/plugs.php</TD></TR></TABLE>
I was kinda hoping for a real solution. BUT ROFL!
Old Dec 30, 2004 | 09:54 PM
Mikizzle's Avatar
If you look inside a 92-95 civic engine bay, the place where you would bolt on if you had a stock GSR strut bar, it should have a rubber cover like the pictures above but painted to match the engine bay. Thats where i found mine in a friends EG engine bay. sorry if i don't make sense
Heres a picture I found (In Red), Its King Tut33 engine bay, if you would like me to take it off, will do.
Modified by GrnTurtle at 11:10 PM 12/30/2004
Old Dec 30, 2004 | 11:15 PM
mine just came with the strut bar and bolts... never had plugs seeing how gsr's come with stock strut towers therefore having a the bolts in there stock..
Old Dec 30, 2004 | 11:32 PM
B-money's Avatar
just went to the acura dealer ship and ordered the plugs for the holes. I'll post up some pics when I get them. they costed like $2.xx for each plug. I got four of them and it costed a total of 10 bucks. I also wanted to buy a typer R sticker for the passenger side quater panel but it costs like 50 bucks at the dealer ship. Does any one know where I can get those for cheaper?
