Need help wiring S2000 front signal lights to 93 Hatch
The signal light harness I have has light grey, blue, and dark grey wires. I need to know which wires they will corespond to on my 93 Hatch. I have the Haynes manual for 92 to 95 Civics so if anyone has the manual for an S2000 I think I can wire it. Thanks
Doing a front end conversion are we?
You can figure it out with a multimeter. First touch one test terminal to the body of the turn signal/parking light socket, and touch the other one to each wire to see which has continuity. That's your ground wire.
Now look at this pic to determine which terminal on an 1157 bulb is parking and which is turn signal (ignore the upper half of the image):
Find the corresponding wire for the parking light coming off the bulb socket. Verify which wire on the car body is the parking light wire by turning on the parking light switch, and use the voltmeter function of the multimeter to see which wire has 12 volts. Now connect that wire to the wire you figured on on the bulb socket, and then the only wires left will be the turn signal.
Sweet! Thanks. I just bought the car and the previous owner added the S2000 headlights, he just didn't bother to wire the parking/signal part
So far it looks like these might be BMW headlights.
They come on this.
(That's a Holiday Rambler Scepter 42.)
But they also come on (some) 1996-2000 BMW 5-Series.
They look awfully like them, but the BMW should use a 9005 and H7 bulbs, but it looks like yours uses a 9005 and 9006 bulbs.
Okay, this is leading me weird places.
They come on this.
They come on this.
Thanks again for taking the time to help me!
dohc_profile
Apr 21, 2006 09:17 PM
