Mini-Me CEL Help
Old Apr 22, 2009 | 07:37 AM
burgsprinta's Avatar
Default Mini-Me CEL Help
Hey, I just swapped a D16y8 Head on my D16y8 Block. There are no codes when i use the P2E ECU from my y7. But, when I use the P2P ECU from the y8, i throw a code P1508 IACV Malfunction.
What causes this and what can be done to fix it? I used the Intake manifold from my y7 Head by the way.
Old Apr 22, 2009 | 02:35 PM
CivicSpoon's Avatar
Default Re: Mini-Me CEL Help
Your manifold has a 3-wire IACV, and the ECU is looking for a 2-wire IACV. Is your car a '96-'98 or a '99-'00?
Old Apr 22, 2009 | 02:52 PM
My car is a 97, the head is off a 96
Old Apr 22, 2009 | 05:18 PM
CivicSpoon's Avatar
Start from about half way down this:
http://www.ff-squad.com/tech/wiring/wiring.96-98.jpg
Then you do this at the ECU:
http://www.ff-squad.com/tech/wiring/...-98_a-plug.jpg
Old Apr 23, 2009 | 07:33 AM
Thanks, One more question though, will i need to find a 2-wire iacv plug if I'm using my old Intake manifold, it is three-wire. So will it still work if i change the pinouts at the ECU? if not, I'm thinking of just using my old ECU with a vtec controller or v-afc.
hugens26
Jun 27, 2013 08:28 AM
Stangracer85
Oct 26, 2009 06:03 PM
Jakester9500
Jan 18, 2007 10:50 AM
jayjay0718
Jul 29, 2006 08:01 PM
viskii420
Oct 11, 2005 11:35 PM
