Mini-Me CEL Help
Mini-Me CEL Help
Hey, I just swapped a D16y8 Head on my D16y8 Block. There are no codes when i use the P2E ECU from my y7. But, when I use the P2P ECU from the y8, i throw a code P1508 IACV Malfunction.
What causes this and what can be done to fix it? I used the Intake manifold from my y7 Head by the way.
Re: Mini-Me CEL Help
Start from about half way down this:
http://www.ff-squad.com/tech/wiring/wiring.96-98.jpg
Then you do this at the ECU:
http://www.ff-squad.com/tech/wiring/...-98_a-plug.jpg
Thanks, One more question though, will i need to find a 2-wire iacv plug if I'm using my old Intake manifold, it is three-wire. So will it still work if i change the pinouts at the ECU? if not, I'm thinking of just using my old ECU with a vtec controller or v-afc.
jayjay0718
07-29-2006 08:01 PM
