anti lock light
because something is wrong with your ABS system. Gotta check the code its throwing to figure out whats wrong with it.
If your OBD1 like me, theres a little green connector under the glove box. It has two plugs in it. "Jump" them with a piece of speaker wire (shove a wire in the holes so they are connected) and turn the car on.
Your ABS light will then flash a code. It will be one quick set of blinks, a short pause, and another quick set of blinks. Write this down and do a search for ABS trouble codes.
For example, mine once threw a 4-8 (four blinks, pause, eight blinks). That's the code for Left Rear Wheel Sensor.
Good luck!
Good luck!
