Can someone tell me about R-81... Milano Red Tricoat/Clearcoat?
Old Apr 22, 2009 | 04:42 AM
MSchu's Avatar
My Name is Nobody
Default Can someone tell me about R-81... Milano Red Tricoat/Clearcoat?
Can I get this color so I can shoot it at home... and what is tricoat/clearcoat?
thanks
Old Apr 22, 2009 | 05:39 AM
precisionsc54's Avatar
Default Re: Can someone tell me about R-81... Milano Red Tricoat/Clearcoat?
its a 3 parts system instead of a 2 part. You have a base color a mid color and a clear
Old Apr 22, 2009 | 09:04 AM
MSchu's Avatar
My Name is Nobody
IC... thanks. would a paint retailer know this and give the correct stuff?
Old Apr 22, 2009 | 09:31 AM
Jasper_db1's Avatar
If you have trouble sourcing it locally out there, LMK and I can pick it up from the supplier I use.
EDIT: Any shop that sells Dupont Chromabase should be able to setup that system for you.
http://seattle.craigslist.org/tac/pts/1130697980.html
Old Apr 22, 2009 | 09:51 AM
ExemptedNut's Avatar
You could buy from paintscratch.com, that's where I plan to get my paint from, they will mix oem colors
Old Apr 22, 2009 | 10:42 AM
ya a paint shop will know its a tri-stage from the code
Old Apr 22, 2009 | 11:07 AM
MSchu's Avatar
My Name is Nobody
wow... duy, that's awesome. 380 to paint a 20 piece though, let me talk to the guy. maybe he's flexible on pricing.
thanks dude
Old Apr 22, 2009 | 11:26 AM
Jasper_db1's Avatar
LMK if you need to borrow a couple of paint guns. I have 1.8 and 1.4 tip guns which I used to paint the YZF.
About that link - he's got the 2-part formula which may not be what you want.
Don't forget about the reducer. Make sure it's fresh and I prefer to use the same brand as the paint I'm shooting.
Old Apr 22, 2009 | 11:31 AM
MSchu's Avatar
My Name is Nobody
how did it come out? Maybe I should send you the part and paint
Old Apr 22, 2009 | 11:38 AM
Jasper_db1's Avatar
I turned out pretty good. It's a lot of prep work and my technique isn't perfect so I spent a lot of time wet sanding the clear. I'm about to finish it off by painting the main fairing since I finally finished the headlight brackets and cutting the holes.
Old Apr 22, 2009 | 01:10 PM
I suggest painting all parts at the same time to avoid shading problems. Pressures can be off tip adjustments etc. This will change the final color outcome. Never paint parts at diff times if all possible. Shoot everything the same day same time with the same mixture.
Old Apr 22, 2009 | 02:17 PM
dc5r2002's Avatar
the milano red can be sprayed as a two part system i forget who makes it i think its nason looks the same side by side.
Old Apr 23, 2009 | 05:25 AM
MSchu's Avatar
My Name is Nobody
Thanks, i need to take a closer look. I only need a small trim part done, but if its to involved I may do a second entire front end(bumper and trim) as a back up to my original units
Old Apr 23, 2009 | 10:27 AM
CaptWalt's Avatar
the base coat is a grey, then the color coat is the red, and then the clear would be the third coat... ive sprayed this color before..
Old Apr 23, 2009 | 10:29 AM
There are alot of variances to this color. From a regular base and clear to a tri-stage. I have seen it done both ways
v8killaz
Paint and Body
Mar 24, 2010 04:08 PM
g35driver
Jan 18, 2007 10:52 AM
mra4886
Oct 31, 2006 03:15 PM
CrAzyGsR101
Nov 21, 2003 06:38 PM
IdotheSHOCKER
23
Jun 24, 2002 07:56 PM
