B series T Bracket differences between VTEC & Non VTEC?
Old Apr 22, 2009 | 12:00 AM
hmtcrxsir's Avatar
Default B series T Bracket differences between VTEC & Non VTEC?
well first of all I want to do an engine swap with a B18c1 in my 95 Civic hatch. So my question is, is there a difference between B Series VTEC and non VTEC. This guy was trying to sell me his T Bracket and said that theres no difference between Integra rear T Bracket. I told him that I bet to differ. So I just want to confirm that I cant use 95 integra LS rear T Bracket on my 95 Civic with B18c1 swap.
Old Apr 22, 2009 | 12:24 AM
Adam_b16a's Avatar
Default Re: B series T Bracket differences between VTEC & Non VTEC?
should work fine. I dont think they are different.
Old Apr 22, 2009 | 12:51 AM
fastrxu's Avatar
part number is the same so.....
Old Apr 22, 2009 | 08:41 AM
hmtcrxsir's Avatar
are you guys sure? last time when i did a B16a swap in my EG the mounting holes for the bolt was not line up. well then again the guy gave me an automatic bracket from automatic car
Old Apr 22, 2009 | 09:25 AM
pvt_awol's Avatar
the only different "t-bracket" is the integra b-series and the civic si (em1) bracket.
The si one will NOT work in a DC or EG chasis. It's too short.
Old Apr 22, 2009 | 05:58 PM
hmtcrxsir's Avatar
so pretty much all the brackets are the same including the LS RS GS GSR? im referring to 94+ integra
Old Apr 22, 2009 | 07:55 PM
CivicSpoon's Avatar
Yes they are the same.
Old Apr 22, 2009 | 09:44 PM
hmtcrxsir's Avatar
sounds interchangeable like D series. I thought many B series parts isnt
Old Apr 22, 2009 | 10:00 PM
kikih22's Avatar
the T bracket from the SI 99 00 is short and the LS bracket is longer so if you use the LS it`ll work fine
Old Apr 22, 2009 | 10:43 PM
hmtcrxsir's Avatar
do i have to switch the rear mount position over to one spot? or do i keep it in the original place?
Old Apr 23, 2009 | 03:44 AM
94EG8's Avatar
Seagull Management
No just leave it in the same place. Any 5 speed '94 - '01 Integra or '94 - '97 Del Sol VTEC T-bracket will work just fine.
Old Apr 23, 2009 | 04:43 PM
hmtcrxsir's Avatar
thank you
95_cxhatch
Apr 9, 2008 04:26 PM
TheDelSlo
Oct 9, 2005 01:38 PM
showtymers619
May 4, 2004 08:40 PM
mannyman
Aug 29, 2002 01:07 PM
