Please clear up s2k brakes on an itr
Old Apr 21, 2009 | 07:54 PM
crexer's Avatar
Default Please clear up s2k brakes on an itr
Ok, i found a couple of threads on this but they always seem to stray off very quickly turning into spoon monoblock calipers. I just got a 5 lug swap for my gsr but it was missing calipers. Itr calipers are expensive as hell and hard to come by and i have a set of 03 s2k calipers i can buy for cheap.
my question is, will i use 11.1" rotor or 11.8" rotor with 03 s2k calipers? any caliper bracket milling required? and will i be using the L caliper on the Right side and vise versa with the bleeder nipples upside down? also if the answer is 11.8" will this fit under a factory usdm type r 15" wheels?
Old Apr 21, 2009 | 09:00 PM
Spids5's Avatar
Don't judge or question
Default Re: Please clear up s2k brakes on an itr
They will not clear usdm itr wheels, I'm not sure about other wheels but I'm pretty sure you will need to run at least 16" wheels. I know that my Mugen calipers which are modified s2k calipers won't clear the stock rims. I'm not sure if all s2k calipers are the same but mine use 11.8" rotors
Old Apr 22, 2009 | 04:39 AM
Tiger_Si's Avatar
i am sorry, i dont have an answer for you.
but ITR calipers are cheap.
i see them for $100 everywhere.
Old Apr 22, 2009 | 08:32 AM
Petah's Avatar
S2K front brakes on a ITR? Interesting....anyone with more solid info on this subject matter? I assume you will use the stock S2K front rotors are well?!
Old Apr 22, 2009 | 09:30 AM
94VTEC2TONE's Avatar
thats pretty much becoming a big new thing. s2k brakes on integras. theres a guy name brakeexpert taht does those swaps. i almost purchases the 911 porsche setup for my teg off of him
Old Apr 22, 2009 | 11:16 AM
racebum's Avatar
exactly. it's a 23T bracket which also came on the v6 accord and earlier legend. i paid $100 for a pair brand new {reman}
Old Apr 22, 2009 | 11:27 AM
RockinaRHard's Avatar
Are you having issues with the stock not working right?
Many ITR guys swear by the stock setup.
So GSR with Stook parts = different forum.
Old Apr 22, 2009 | 03:21 PM
TeamJDM's Avatar
99 Honda CRV front calipers are the same as ITR's
Old Apr 22, 2009 | 04:45 PM
crexer's Avatar
ok guys if you can find me a set of itr calipers for the front in decent shape, and the transaction goes through i will paypal you 5.00
lets see what you can do
Old Apr 22, 2009 | 04:55 PM
robfrmny21's Avatar
can't you use the 23t bracket with the gsr caliper?
Old Apr 22, 2009 | 05:50 PM
crexer's Avatar
maybe. got some extra 23t brackets laying around?
Old Apr 22, 2009 | 06:16 PM
racebum's Avatar
no, the caliper is literally too small. that's the reason you need the 23T bracket to do the ITR upgrade to a GSR
Old Apr 23, 2009 | 08:04 AM
HondaRcB's Avatar
Pretty sure you can get reman ITR calipers for $100 or so.
Old Apr 23, 2009 | 09:02 AM
sheekdude's Avatar
S2k setup wont work on an itr. I just put spoon ap1/dc5 calipers on my itr and i had hell finding out what worked and what didnt. You are right in that itr's are 11.1 and s2k 11.8 but the itr hub its one of a kind... way bigger than the standard honda 5 lug hubs. The holes line up but the rotor doesent fit over the hub. You'll have to take it to a machine shop to have them grinded down. I might have a set of itr calipers and brackets laying around. $150 picked up.
or..
You can buy 97+ crv spindles but they are going to be 36mm like the jdm itrs, but you can use 02+ rsx base model hubs which are 32mm and also is the standard honda 5 lug setup. Now you can buy those ap1 calipers and brackets, along with rsx type s rotors (11.8) and use the bigger brakes.
Hope this info helps. User name BrakeExpert was kind enough to pass on to me but he's no longer on this site.
Old Apr 23, 2009 | 05:11 PM
ejwan's Avatar
or..
was going to state the same. I research this awhile back when i had a jdm ctr setup from an ep3. When i found out it didn't work (didn't expect it to) i had to research. Bascily the crv uses the same bearing as the rsx base and type s. There for you will just need 2 hubs, 2 bearing and a press. BTW this will also work if you need to make your jdm itr 5-lug from 36mm to 32mm. Thats my 2cent lmk if you need more
Old Apr 23, 2009 | 05:20 PM
ejwan's Avatar
some pn
44300-S47-008 wheel bearing cr-v, jdm itr, rsx base, rsx type s (all use the same one)
44600-S7A-000 32mm hub rsx base
44600-S87-A00 36mm hub rsx type s
44600-S47-000 36mm cr-v/jdm itr hub
Hope that helps
Old Apr 24, 2009 | 03:40 AM
sheekdude's Avatar
Thank you for the p/n's... the op shouldn't have any problems now... i hope.
Old Apr 24, 2009 | 06:26 AM
highroller54's Avatar
I have jdm 36mm spindles and mugen brakes for sale if anyone is interested
Old Apr 24, 2009 | 08:50 AM
ejwan's Avatar
haha mugen brakes are the same as the s2k. honda i guess made the hub on the s2k purposely smaller so that jdm itr cant have a direct bolt on hence they will have to buy mad expensive rotors for it to work lol. Well I hope this helps out anyone that want to do the swap. I wish I had the funds to do it already and will probally do a write up if I do to help ya out. Have other priority for the car right now so the jdm ep3 ctr stuff is just chilling.
Old Apr 26, 2009 | 05:05 PM
crexer's Avatar
thanks guys, i think im just going to suck it up and get itr calipers and do it the non-hybrid way. thanks again
Old Apr 26, 2009 | 06:31 PM
baysic r's Avatar
why not use nsx or legden calibers. does the s2k use a dual piston set like the nsx?
Old Apr 27, 2009 | 03:34 AM
sheekdude's Avatar
S2k uses a single piston caliper.
Mattcuzko
Suspension & Brakes
Nov 15, 2011 06:43 PM
BrowNKiD
Suspension & Brakes
Jan 9, 2010 12:12 AM
Kamikaze_ITR
Sep 27, 2006 09:00 AM
Ls1 FD3s
Feb 13, 2005 09:35 PM
Money Hou$e
May 17, 2003 02:35 PM
