Problems changing alternator in '90 lx sedan
Old Apr 21, 2009 | 04:59 PM
90lxsdn's Avatar
Default Problems changing alternator in '90 lx sedan
Alright, well i bought the car for $250 and the only thing that is holding me back from driving it is the alternator.
So i go to change it this weekend and the bottom bolt is completely rusted on. Every other bolt is fine except this one, it sucks. Ive tried using rust buster, then wd 40, pb blaster, i tried heating it up with a little propane heater, used some vice grips and all i am doing is rounding the bolt off.
Anybody have any other tips on how to get this thing off? I dont wanna damage the stud, could really give 2 ***** about the nut though.
Thanks
Old Apr 21, 2009 | 06:08 PM
sde780's Avatar
Default Re: Problems changing alternator in '90 lx sedan
Hey, same problem here. Are you talking about the inside one or the outside one? Soak it in PB Blaster for a week, do it everyday. I bet it'll come out
Old Apr 21, 2009 | 06:18 PM
Tarmac Junkie's Avatar
If its that damaged you could always cut it with a torch, and just buy new hardware for it...
Old Apr 21, 2009 | 06:53 PM
90lxsdn's Avatar
I guess its the one on the outside? its when you take the left front wheel off then the splash shield and its the bolt on the botton.
Old Apr 21, 2009 | 06:55 PM
90lxsdn's Avatar
Yeah i was thinking about a torch, but i dont have access to one at home. And since the car has a bad alternator i would have to tow it to a garage since it most likely wouldnt make it
Old Apr 21, 2009 | 06:59 PM
sleepingciv's Avatar
if the nut is off which i assume it is. use MAPP gas and heat it up the end f the bolt with the threads on it. use a small sledge hammer and a nice size punch and drive the bolt out.
When you do get the old one out, cover the new bolt in axle grease so it dont size up again. If ya need a new bold and nut i have one here
and this might work also but it will take for ever and be a bitch use a 14 mm wrench and remove the bracket that holds the alt in place. then take it somewhere to remove the bolt.
you will need to turn the 2 bolts little by little but it will come off, remember this will take a long time lol
Old Apr 22, 2009 | 10:37 AM
90lxsdn's Avatar
Nah the nut is not off. That is what i cant get to come off
Old Apr 22, 2009 | 12:01 PM
mjfubar101's Avatar
Get an easy off tool from sears or a hardware store they bit into the bolt or head of the nut and allows you to take it off. It will be a pain where its located but it will come off. Then go and buy a new bolt and nut.
http://www.sears.com/shc/s/p_10153_1...d+bolt+remover
mr darcko
Jun 30, 2024 02:00 PM
efjones9
Oct 18, 2009 07:16 PM
peter_x
Aug 23, 2009 08:01 AM
sixgunsound
Jun 5, 2009 11:06 AM
