Low Idle after warm up
Old Apr 21, 2009 | 03:37 PM
dc2doi's Avatar
Default Low Idle after warm up
1999 prelude base model.
After warm up the idle seem to be around 400 rpm. I tried to adjust the idle screw still nothing.
No check engine light.
It would stall on me whenever I'm making a turn and not pressing the gas. Drives perfectly fine but it wont idle low after warm up. Like it wants to stall.
Anyone has any idea what this could be?
Old Apr 21, 2009 | 03:55 PM
bluedlude's Avatar
Default Re: Low Idle after warm up
check that the FITV and IACV are working properly
Old Apr 21, 2009 | 05:45 PM
Rice Petrol's Avatar
Check in this order
1. IAC valve
2. fuel injector
3. Electrical load detector
Old Apr 22, 2009 | 01:14 AM
smackdown's Avatar
where is the electrical load detector located?
Old Apr 23, 2009 | 04:03 PM
**edit**
The ELD is built into the under hood fuse box sadly, I will try to find the flowchart for diagnosing the ELD is to verify if it is faulty or not but make no promises as of now...
Old Apr 23, 2009 | 04:31 PM
Btw have you hooked up a OBD scanner to verify that it is not storing a code?
The ELD will usually set off a MIL/DTC if it or the circuit is faulty...
Old Apr 25, 2009 | 06:31 PM
dc2doi's Avatar
Car isn't throw any kind of engine code. I cleaned the IAC today, still does the same thing.
Not exactly sure what a ELD is. More information on this?
Old Apr 25, 2009 | 06:50 PM
duanes's Avatar
The idle system is relatively simple in operation. The basic idea is just to bypass the throttle plate and let more air in. The ECU and fuel injection system will automatically adjust the fuel mixture so that the end result is an increase in engine speed.
1. Let engine warm up completely.
2. Unplug the IAC. This is a two wire gadget on the drivers side front of the throttle chamber and pointing slightly down. If the IAC is functioning, you should get a drop in rpm. In a short period of time, you will also get a check engine light.
3. Make sure that the throttle cable allows the throttle plate to close completely. There should be a small amount of slack in the cable.
4. Adjust the RPM to about 500 rpm with the idle screw. (Inset screw on the top, passenger's side of the throttle body and facing the passenger wheel.
5. Plug the IAC back in. RPM should rise to about 830 for Auto tranny and 870 for Manual.
If the screw has no effect, it may be plugged with gunk. Same with the IAV and CAV. They all have little screens in them or they are small holes that build up with oil and dirt over time. I have heard that you can remove the idle screw and clean the passage way with a pipe cleaner.
xfactor4774
Apr 17, 2014 12:28 PM
jah.tien
Jul 14, 2010 10:37 AM
em1gangsta
Jan 26, 2008 03:40 PM
bertyman
Dec 11, 2005 04:15 PM
tarheelsoldier
Jan 27, 2005 11:02 PM
