engine swap on dc help
Old Apr 21, 2009 | 03:03 PM
lileghatch's Avatar
Default engine swap on dc help
hey whats up i have a 94 integra and i seem to not be able to remove the controls arms....so pretty much i cant get my cv axles out to actually swap engines.....so i need suggestons cause iam really ****ed right now...thanks
Old Apr 21, 2009 | 03:04 PM
Hanmin's Avatar
Default Re: engine swap on dc help
the control arms? There's cotter pins. As a last chance I would either go to a shop, or take the hubs off with the motor.
Old Apr 21, 2009 | 03:05 PM
lileghatch's Avatar
yes those cotter pins....i already have the car jacked upughh its hard
Old Apr 21, 2009 | 03:10 PM
jasons9594's Avatar
wt hell? take the hubs off? all u have to do is take the 17mm nut off the lower ball joint and use a pry bar between the upper control arm and the spring (prying up) and hit the side of the lower control arm with a hammer where the ball joint stud goes threw the control arm....i would leave the nut on a couple threads though so if u miss u dont damage the threads .....
Old Apr 21, 2009 | 03:11 PM
lileghatch's Avatar
what are hubs....
Old Apr 21, 2009 | 03:13 PM
jasons9594's Avatar
Originally Posted by lileghatch
what are hubs....
i hope ur kidding? if not the hubs are the things the axle goes threw that the wheel studs stick out of...
Old Apr 21, 2009 | 03:16 PM
lileghatch's Avatar
i call them rotors...my bad.....well ive beat the **** out of them and still nothing....can i just take the whole assembilyy off
Old Apr 21, 2009 | 03:18 PM
jasons9594's Avatar
beat the f out of what u shouldnt need to take any of it off if ur just trying to get the axles out
Old Apr 21, 2009 | 03:19 PM
lileghatch's Avatar
the hub he axel can comehas to swing to the side that way the axle can come out
Old Apr 21, 2009 | 03:23 PM
jasons9594's Avatar
dudue uve lost me u should only have to unhook the lower ball joint to swing it out enouph to get it out of the trans and then u will have to take the lower wishbone part of ur strut off to remove the axle once uve take the big axle nut off the outside of the axle off
Old Apr 21, 2009 | 03:25 PM
sp00ledbseries's Avatar
IF you cant get the ball joints popped loose. take and unbolt the top ball joint from the strut tower and take the shock fork off the control arm. then you can turn the whole hub assembly left or right and have room to get the axle out
Old Apr 21, 2009 | 03:27 PM
jasons9594's Avatar
x2 agreed
Old Apr 21, 2009 | 03:42 PM
Luke G.'s Avatar
could you translate that to english?
Old Apr 21, 2009 | 06:29 PM
lileghatch's Avatar
thanks for your help guys...i got it off and iam putting in my gsr tommrow...thanks for all the info
unclematt
12
Jun 2, 2016 04:31 AM
tree fingers
Feb 18, 2008 10:41 PM
CRX_Control
Aug 8, 2005 03:26 PM
illusion
Oct 13, 2002 10:45 AM
