will valves clear gsr block gsr rods ctr pistons b16 head
will the valves clear a b16 head on a gsr block with real ctr pistons im going to be useing a 0.040" head gasket i need to know if the pistons will clear the valves saftly in and out of vtec i need to know asap if not will a 0.050" be better also planing on use ctr cams
according to http://zealautowerks.com/bseries.html your compression will be at 12:73.1 kinda high huh.
wouldnt you have to upgrade your valve train if you go with the ctr cams??
lol i know its high lol planing a track car with it lol thats y lol i chould use a 0.050" head gasket lol but at that point i might as well just get a slab of copper cut to fix the problem lmao
ps with the 0.040" head gasket the compression will be 12.20:1 and with the 0.050" head gasket it will be 11.84:1
with that CR you will need to run bigger cams than stock ctr's
honestly they are a waste of money, because for 450 you can get ctr cams online or for around 600-700 you can get skunk2 tuner cams, and they are WAY better
i have s2 stage2 cams and when i crossover into vtec my car takes off.
i would say you should get tuner series 3 cams from skunk2
and you can get them for a good price through these guys
www.wickedinnovation.net
streetsold6teeny8
Apr 3, 2010 11:13 AM
vtecmonster001
15
Apr 10, 2007 08:10 PM
jdmjeff
11
Nov 18, 2005 04:34 PM
