OEM Rebuild B18C1
Old Apr 20, 2009 | 08:40 PM
CRX MASE's Avatar
Default OEM Rebuild B18C1
Im picking up a b18c1 from a buddy that has 200k on it. I plan to rebuild it using all oem parts. Im buying oem pistons,rings,bearings, ect ect. I have a few questions the motor runs fine as it is, Is it fine to reuse the rods even though they have over 200k on them? Should i replace valves,springs,valve guides, and cams because of the mileage? Or can i just reuse everything in the head and have a valve job done?
Just looking for opinions on this, motor will be going in my ek hatch and i just want a reliable motor that i can beat on ever now and then.
Old Apr 20, 2009 | 08:52 PM
Blazin Si's Avatar
Loved
Community Favorite
Default Re: OEM Rebuild B18C1
I would think the original rods would be fine, but I'd replace the valves and springs. If you're pulling from the Honda parts bin, why not mill the head a bit and drop in some ITR cams?
Old Apr 21, 2009 | 12:26 AM
So FReSh's Avatar
why not try and build a bit more power on the rebuild. itr pistons.valvetrain.cams.etc? and as for the rods.just get them shot peened.
on my build the one thing i wish i did was get a mild pnp.
Old Apr 21, 2009 | 04:57 AM
tealchief's Avatar
are going to hone the block or anything?
Old Apr 21, 2009 | 09:04 AM
CRX MASE's Avatar
yes, maybe bore it.
Old Apr 21, 2009 | 09:10 AM
mar778c's Avatar
Community Builder
Community Influencer
1) recondition the rods.
2) Bore and hone, if you want the new rings to actually seal.
3) With 200k miles, I would say yes the valves, guides, LMAs, maybe seats should be replaced. The best thing to do is send the head to a competent porter and let them recommend what to do. Your really can't tell over the internet.
Old Apr 21, 2009 | 07:42 PM
illfaded's Avatar
yeah get type r pistons and balance the crank while ur there. dont just go back to stock gsr. build it up for a little extra.
xotic_crx
17
Oct 28, 2014 04:00 AM
phelpsj2
Jan 16, 2012 05:22 PM
victor.ek4
28
Aug 2, 2009 02:43 PM
krazy one
33
Sep 29, 2007 01:53 PM
gamblezhang
Mar 27, 2006 11:13 AM
