ls integra wont rev past 4k rpms..please help
Old Apr 20, 2009 | 08:31 PM
jdmasfck's Avatar
Default ls integra wont rev past 4k rpms..please help
motor wont rev past 4k rpms..not exactly sure why..i was told it could be the timing,tps, or a bad ground..its still drives just cant take it past 4k rpms..any ideas of what it could be???
Old Apr 20, 2009 | 09:23 PM
Hydro_Da's Avatar
Default Re: ls integra wont rev past 4k rpms..please help
check your spark plugs.
spark plug wires.
i've been told it could be a clogged cat?
Old Apr 20, 2009 | 09:24 PM
phateless's Avatar
How well does it run otherwise? Normally? Is it throwing any codes? There's obviously SOMETHING wrong with it...
bmwpride's Avatar
check your plugs, wires, cap,and rotor. Your running on limp mode, so also unplug your battery for about 10mins and try it again
Old Apr 20, 2009 | 09:30 PM
jdmasfck's Avatar
it has new plugs wires cap and rotor....and yeah it runs fine other then not reving past 4k...i still gotta check the codes
Old Apr 20, 2009 | 09:31 PM
phateless's Avatar
Start with the codes because they'll TELL you what's wrong with it. What kind of mods are on the car?
Old Apr 20, 2009 | 09:32 PM
jdmasfck's Avatar
yeah ik lol i just havent gotten around to that yet lol
Old Apr 20, 2009 | 09:37 PM
phateless's Avatar
i hear that. do some searching, because it's easy as hell and takes about 15 mins. you could also go to kragen where they'll plug in the code reader for free.
Old Apr 20, 2009 | 09:41 PM
jdmasfck's Avatar
yea i think im goin to do that tomorrow lol...i just hope its a simple fix..
Old Apr 21, 2009 | 05:44 AM
slowac's Avatar
Default stock ls won't rev past 5k
bone stock ls integra's won't rev past 4500-5000 rpm's. depending on the gear. new fuel filter, new fuel line from filter, new rings all New bearings. engine completely rebuilt. oh and sometimes when you come to a stop it trys to stall. any ideas?
Old Apr 21, 2009 | 06:13 AM
96GS-R-Kaden's Avatar
Once you get the codes that your car is throwing, the answer you will get will be a bit more specific
Old Apr 21, 2009 | 06:48 AM
slowac's Avatar
mine is doing same thing just no codes at all.
Old Apr 21, 2009 | 06:58 AM
What yr. is it?
Old Apr 21, 2009 | 07:24 AM
slowac's Avatar
1996 with obd2-obd1 jumper
Old Apr 21, 2009 | 07:57 AM
redlinetuning's Avatar
Not to be a jerk or anything, don't jack the thread. Start a new one listing your setup. It gets all too confusing.
Old Apr 21, 2009 | 08:34 AM
backyard_concepts's Avatar
my buddys civic does the same thing and its his dizzy. just a suggestion.
Old Apr 21, 2009 | 08:39 AM
slowac's Avatar
yeah sorry bout the highjacking. just getting frustrated
Old Apr 21, 2009 | 09:32 AM
mpls's Avatar
**** the limp mode is either your dizzy or 02 plug
Old Apr 21, 2009 | 10:09 AM
phateless's Avatar
That would **** me off to no end. I couldn't make it one day below 4k rpms, lol.
Old Apr 22, 2009 | 10:55 AM
jdmasfck's Avatar
dont got the car anymore..now im looking at a super clean DA
Old Apr 22, 2009 | 10:59 AM
sp00ledbseries's Avatar
Old Apr 22, 2009 | 02:33 PM
phateless's Avatar
That's one way to solve your problem. What happened to it??
Old Apr 22, 2009 | 05:43 PM
jdm_bones's Avatar
Yes, it sound like your in limp mode....Check your codes, and fix the promblem, then rest ECU, and check to see if continues, if it does, there is another issue. Report back, or post your codes, for more ideas.
Old Apr 22, 2009 | 07:08 PM
90IntegraTuner's Avatar
Check your thermostat housing...if you bounce at 4000 4500 with a flashing code you have a ground that is not fully connected...make sure that you thermostat housing is bolted down good and the ground for the coolant temperature sensor is connected and secured...
...that is if you are still looking for an answer
Old Apr 23, 2009 | 01:12 AM
jdmasfck's Avatar
sold the 96 now im looking at a DA thats super clean
