question about oil
Old Apr 20, 2009 | 07:51 PM
teg_dc2's Avatar
Default question about oil
so when i reach 75k miles do i need to switch from mobil1 full synthetic to high mileage oil or can i still use mobil 1 after 75k miles??
Old Apr 20, 2009 | 08:08 PM
90IntegraTuner's Avatar
Default Re: question about oil
You dont have to go to high mileage oil but its recommended because in high mileage oil there are extra additives to help seal worn down piston rings and what not...i still use regular mobil 1 in my b16 that has about 90k on it and its fine but i will eventually switch over to a high mileage oil...it never hurts
Old Apr 20, 2009 | 09:56 PM
TOO MUCH TORQUE's Avatar
i switched to synthetic at the miles
Old Apr 21, 2009 | 06:04 AM
nsxtasy's Avatar
H-T Order of Merit
You can use either one.
Old Apr 21, 2009 | 08:05 AM
SkaiWu's Avatar
can you still do some hard running or autox when you use high mileage oil ?
lol high mileage oil sounds like something just to keep an old man/women alive
Old Apr 21, 2009 | 09:16 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
The previous owner of my car used Castrol GTX, then when I bought it at 89K I switched to Mobil1 5w30 fully synthetic. I used that for a little over a year, then switched to Valvoline MaxLife at about 110K because I couldn't get the M1 as cheap as I could before.
Been running MaxLife 5w30 year-round ever since then, for the past 165K+ miles. Car has 276K+ on it and still runs like a top.
So I actually switched from dino to synthetic AFTER 75K, and then switched back to dino again (MaxLife is now a synthetic blend, though), and have never had a single problem.
Old Apr 21, 2009 | 12:21 PM
nsxtasy's Avatar
H-T Order of Merit
Yes.
Old Apr 21, 2009 | 01:42 PM
teg_dc2's Avatar
so its ok to keep putting in mobil 1 past even 100k miles? or should i switch to high mileage oil to be safe?
Old Apr 21, 2009 | 02:04 PM
rebar71's Avatar
I'm at 141,500+ miles on the odometer and counting.
I am running Mobil 1.
Old Apr 21, 2009 | 04:10 PM
Hydro_Da's Avatar
dont mean to thread jack but i've been wondering myself.
my da is stock [engine wise] with 250,xxx on the odometer.
what oil brand and viscosity would you guys suggest i use?
Old Apr 21, 2009 | 05:12 PM
Tarmac Junkie's Avatar
Amsoil ftw... The true full synthetic.
Old Apr 22, 2009 | 10:06 AM
teg_dc2's Avatar
im at 59k on my dc2 right now, just recently changed from a regular oil to mobil 1
Old Apr 22, 2009 | 10:19 AM
if the oil youve been using is treating you well, stick to it
Old Apr 22, 2009 | 10:31 AM
Hydro_Da's Avatar
well brand, i never really paid attention to it as long as its not no name oil.
and viscosity, i use 10w40.
too thick?
i like what i've been hearing about mobil1, i think ill switch to that.
Old Apr 22, 2009 | 10:56 AM
mrdeadman's Avatar
They let me pick
too thick?
10w-40 is thick.
I would switch to 5w-30 or 10w-30 (if you are in a warmer climate). Try it out. If you are burning excessive oil, you should probably do a rebuild...
Old Apr 22, 2009 | 11:07 AM
Hydro_Da's Avatar
Originally Posted by mrdeadman
10w-40 is thick.
im in socal.
yeah, a rebuild is not an option right now.
lol
so im guessing 10w-30 would be better?
Old Apr 22, 2009 | 11:14 AM
DC206R's Avatar
if you're in SoCal. I think you should just stick to 5W-30. Honda recommends 5w-30 anyways.
Old Apr 22, 2009 | 11:16 AM
Hydro_Da's Avatar
even with 250,xxx miles on the odometer??
Old Apr 22, 2009 | 11:22 AM
racebum's Avatar
yes, even with that mileage. if you're burning a lot of oil, well, you have 250k miles. 10-40 really isn't going to slow that down. you might start thinking about what your next move with the motor is.
Old Apr 22, 2009 | 11:29 AM
mrdeadman's Avatar
They let me pick
Honda also recommends 10w-30 depending on the min temperature of the climate...
It doesn't really matter which one.
5w will probably give a little easier start up.
I'm switching to 0w on my next oil change and we'll see what happens...
Old Apr 22, 2009 | 11:45 AM
Hydro_Da's Avatar
thanks for the input guys, even though it wasnt my thread.
lol
sorry for hijacking.
Old Apr 22, 2009 | 12:11 PM
teg_dc2's Avatar
lol
^thats ok, lol!
well im using 10w-30 i live in socal so i guess thats ok since its warm usually all the time here
Old Apr 22, 2009 | 12:20 PM
Community Builder
I use 5w-30 year round with 276K miles on the engine. Since I replaced the leaky oil cooler o-ring last Thanksgiving, I've only been losing maybe 1/2 quart at the MOST in 3K miles.
Note: at operating temperature, 5w-30 and 10w-30 are THE EXACT SAME viscosity. The only difference is 10w is thicker when cold. 80% of engine wear happens during cold start-up, so really an engine should last longer using 5w-30 all the time.
Really the best option would be 0w-30, but that weight is generally expensive and hard to find. However I am considering trying Amsoil's synthetic 0w-30 with their oil filter and using it for their recommended 15K mile/1 year oil drain interval and see how it goes. Right now that would be cheaper than changing my oil 4 times a year with Valvoline MaxLife.
Old Apr 22, 2009 | 12:33 PM
racebum's Avatar
do you ever drive that car very hard pat? i know most of the track guys {including myself} burn a quart every 1500 or so with auto-x, weekend drags and all out back road driving.
Old Apr 22, 2009 | 12:35 PM
Community Builder
Mostly just commuting to and from work, but I do get on it and redline it 8K rpm on an on-ramp every once in awhile.
