Expert needed: Grabbing brakes.
Old Apr 20, 2009 | 07:42 PM
Eighty-Nyne's Avatar
Default Expert needed: Grabbing brakes.
Ok...
My brakes grab. But only after driving 15 miles.
When they grab, my brake pedal is as hard as a rock. If I turn off the car and let it sit 10 minutes. They wont grab again until I drive another 15 miles.
My car has:
New front calipers
New master cylinder
New rear wheel cylinders and shoes
Thoroughly inspected brake lines.
100% fresh brake fluid.
Turned rotors.
I'm thinking I got a faulty master cylinder. Could a master cylinder do this? Proportioning valve? I don't know.
I'm beginning to want to light this car on fire.
Old Apr 21, 2009 | 05:59 AM
ef-hatchcrap's Avatar
Default Re: Expert needed: Grabbing brakes.
Brake booster is going bad. After driving for a while do the brakes tend to lock up and ytou cant go anywhere?
Old Apr 21, 2009 | 07:30 AM
91-CRX-Si's Avatar
I got the same problem changed the same things,still have the problem,I changed brake booster to.The one thing i did do is an Si rear disc setup,but problem was there before I did this.Now my new brake booster is for STD model,but the master cyl. is for an Si.I don't think this matter.I think it could be a vac.problem with the intake.I don't know swaping motor anyway I'll find out then. If anyone has an answer to this problem I would love to hear it.Thanx
Stanceman
Dec 28, 2017 05:41 AM
CarBug
Jun 12, 2016 01:51 PM
SlammedEG6
Aug 16, 2010 12:46 PM
starlily61
Jul 13, 2007 12:38 PM
bruvaman
Jul 9, 2002 07:19 PM
