which fuel filter?
Old Apr 20, 2009 | 05:54 PM
Gofmf's Avatar
Default which fuel filter?
My set up is an external 255 fuel pump with an 8an feed into the engine bay and a 6an return. My motor is a basically stock ITR, (the car came with this fuel set up and was once turbo).
I was wondering what fuel filter I should run? I've been looking into earls, aeromotive russell, etc.. Could anyone point me in the right direction on a nice quality fuel filter and what microns etc...?
Thanks in advance.
Old Apr 20, 2009 | 07:03 PM
jlude90's Avatar
Default Re: which fuel filter?
i have the edelbrock PN 8130
but here is the Russel line which is the same, and that you said you have looked at
http://www.russellperformance.com/mc...ers-comp.shtml
Originally Posted by Edelbrock
HIGH FLOW FUEL FILTERS
Designed for high volume fuel systems these high-quality fuel filters are manufactured of billet aluminum and offer 40 micron filtration. These filters are 3" long by 1-1/4" in diameter and include a 40 micron disc element with a ?6 male inlet/outlet. Match with Edelbrock pump-to-carb fuel line kits for a complete plumbing solution.
its held down with a thing from a wiring harness, i can't even think of what to describe it as, but i've been running it about a year and its worked well so far
Old Apr 21, 2009 | 01:34 PM
Gofmf's Avatar
thanks for the feedback, will a filter that small be enough for my entire system? I'm not running an oem fuel filter on the firewall and no other filters.
Old Apr 21, 2009 | 07:21 PM
jlude90's Avatar
same here, thats the only filter in my entire system
cmwalker
Jul 12, 2012 12:10 AM
xsi-t
May 30, 2011 05:16 PM
I B BANGGIN
Jan 14, 2007 06:57 PM
dustin
Oct 2, 2001 04:23 PM
