car won't pass inspection
Old Aug 15, 2002 | 07:00 PM
civicsport's Avatar
Default car won't pass inspection
guys i need help, my car keeps failing inspection and i need to know why, i changed sparke plugs and wires, what else do i need to change so i can pass
Old Aug 15, 2002 | 07:05 PM
ZCPOWER's Avatar
Default Re: car won't pass inspection (civicsport)
What setup are you running?(engine,mods)
Old Aug 15, 2002 | 07:19 PM
civicsport's Avatar
Default Re: car won't pass inspection (ZCPOWER)
d16z6 engine, cheap intake, stock header, pacesetter catback, landspeed cat converter
Old Aug 15, 2002 | 07:31 PM
USDM 4G VTEC's Avatar
depending on what ecu u using i can say ur running rich
my Z6 its running rich.......
all i can tell u to do know (since i am all tired) its to get a fuel rpess regulator and lean that baby!!
after u set it low.,..... reset ecu and go back and try it
should help a lot......
Old Aug 15, 2002 | 07:41 PM
ZCPOWER's Avatar
Default Re: car won't pass inspection (JDM EF9)
Yeah lean it out and that should do the trick.My car never passes so i always have to pay.
Old Aug 15, 2002 | 07:48 PM
civicsport's Avatar
im using a p28 ecu
Old Aug 15, 2002 | 08:53 PM
big pete's Avatar
if you use a hf ecu...you car wont run right
Old Aug 16, 2002 | 10:30 AM
Blaze45's Avatar
Brrraaaap!
Default Re: car won't pass inspection (big pete)
After doing whateveryone else said rev your car for about 20-25 mins< this helps clean out the carbon deposites and is your cat 50 state legal>? if not switch back to the stock one for smog testing. Hth
Blaze
Old Aug 16, 2002 | 03:42 PM
88_SC_CRX_Si's Avatar
New User
If you try lowering the fuel pressure trick, just make sure you keep your foot out of it. Otherwise, you won't have to worry about getting that engine checked again.... hehehe
What color are your plugs and is it uniform?
Might check your MAP sensor hose for fitmit, cracks ect...
Make sure your engine is at full operating temp.
Have the fuel pressure checked, it wil tell you if the fuel pressure regulator needs re-placed.
Has the oil ever been changed, just before testing. Unburned fuel starts collecting in it, along with other nastys. Which gets fed back into the intake. By the PVC valve, and the return from vent on the valve cover.
Just some thoughts...
lxz6
May 28, 2010 01:36 PM
gurlugotmilk
Feb 6, 2009 06:29 PM
killrB
Feb 9, 2008 07:03 PM
mike03,95civic
Dec 7, 2007 11:32 AM
sharky8513
Feb 8, 2005 11:14 AM
