1993 integra cold idle issue...please help
Old Apr 20, 2009 | 05:37 PM
EK 2 9K's Avatar
Default 1993 integra cold idle issue...please help
ok heres the deal....the car has always had a little bit of a bouncy idle and no one else ever noticed but me and i wanted it gone because it bugged me. i cleaned out the IACV let it dry and put it back on...no cigar. i mentioned it to our master tech at work and he adjusted the thermal wax valve on the back of the intake manifold. IT MADE IT WORSE! i think i got it back to where the thermal wax valve was but it still runs like it has a stage 9 cam in it when cold. as soon as it warms up it idles fine....anyone have any ideas? when cold it idles between 500-900 no like a surge tho. its just really choppy. NO MIL.
PLEASE HELP
Old Apr 20, 2009 | 06:03 PM
EK 2 9K's Avatar
Default Re: 1993 integra cold idle issue...please help
bump...need help asap. i am going to go try resetting the ecu and possibly making sure everything in the distributor is tight. i just replace the coil
Old Apr 20, 2009 | 10:11 PM
Silver89crx's Avatar
did u check the fast idle valve under the throttle body.
Old Apr 21, 2009 | 06:28 PM
EK 2 9K's Avatar
wow this thread moves fast... i will look into the fast idle valve. not sure where it is but im sure i can find it
Old Apr 21, 2009 | 06:59 PM
EK 2 9K's Avatar
more info....this only happens if the car is STONE cold....only if it sits over night or for probably 6+ hours...just tried to find the fast idle valve i think we are referring to the same valve but the guy at work called it a thermal wax valve...also smells a little rich when this happens....SOMEONE PLEASE HELP
Old Apr 21, 2009 | 09:13 PM
pdeniz's Avatar
u probably just need to replace ur iacv ... I cleaned out mine and the same thing happened until I replaced it
Old Apr 22, 2009 | 04:40 AM
MD426's Avatar
Will this help?
Make sure your PCV valve isn't clogged up, clean or replace air filter, after you clean both the IACV and FITV reset your ECU and let it run until it warms up with out touching the gas pedal then shut off.
Old Apr 22, 2009 | 11:10 AM
EK 2 9K's Avatar
^^thank you...yeah that is what was adjusted. according to the guy at work its supposed to be screwed all the way in. and thats when my problem came about. i attempted to put it back where it was but no luck....any suggestion on how to adjust it without breaking knuckles. thats a bitch to get at.
Old Apr 22, 2009 | 11:42 AM
The G2 Racer's Avatar
Remove it?
Try replacing it with a new one.
Old Apr 22, 2009 | 11:47 AM
jdm_bones's Avatar
X2 try to clean out with carb cleaner first, make sure that u remove the seal, so the carb cleaner wont damage it...Also cheack all your vaccum lines...You might also have a bad Intake manifold gasket, that is leaking air in...Might need to replace that as well, check for a hissing sound coming from the mani when it is shut off...
Old Apr 22, 2009 | 11:50 AM
EK 2 9K's Avatar
just adjusted the fast idle valve. took it off, cleaned it out. i sprayed carb cleaner around the manifold to see if the idle would rise to find a leak and nothing. i am hoping adjusting the fast idle valve will fix it...fingers crossed
Old Apr 22, 2009 | 12:22 PM
MD426's Avatar
I have a repair guide for 90-93 integras and it recommends not to touch the FITV at all, the old reason you would need to adjust it is that some one else messed with it. Just cleaning it out should have fixed it.
An easy way to check if it's working is to let the car cool down completely, pull off the air intake tube off of the throttle body and start the car, put your finger over the lower hole in the throttle body, you should feel suction, when warm it should be closed and no suction.
Old Apr 22, 2009 | 01:25 PM
The guide is ****. Many people (myself included) have fixed there bad cold idle by tightening the FITV all the way down.
OP, try this link: http://www.g2ic.com/forums/showthread.php?t=42969
Old Apr 22, 2009 | 04:06 PM
EK 2 9K's Avatar
^^wow thanks...amazing write up. i i didnt fix the issue i will definately check into that!
THANKS!
crazykid9137
Aug 18, 2007 02:09 PM
redferio
12
Nov 5, 2006 06:00 PM
DK4200
Feb 23, 2003 09:33 AM
