My ls/vtec build...how much hp?
Hey guys am i the process of building a all motor ls/vtec Eg hatchback...just cant wait till its finished..
b16 head
ported & polish head
Skunk2 pro 2 cams
ferrea valves, valves springs, & retainers
ported skunk2 intake manifold to match the head
blox 68mm TB
315cc injectors
AEM fuel rail & fpr
b18a1 block
micropolished crank
gsr oil pump and water pump and timing belt
scat rods
12.1 je piston
acl race rod and main bearings
je piston rings
hytech headers
gsr tranny
trying to run it on hondata s200 or s300
Am just wondering what you guys think the numbers am pulling at the dyno whp..& in a 1/4 mile.....
Am hoping for between 200hp-220hp... & running high 12,s or low 13,s
Is it possible?????
b16 head
Skunk2 pro 2 cams
blox 68mm TB
315cc injectors
AEM fuel rail & fpr
b18a1 block
micropolished crank
scat rods
12.1 je piston
je piston rings
hytech headers
gsr tranny
Is it possible?????
to be honest, i used a gsr transmission for a little over a year and then switched to a b16. the shortness of the gears is awesome, i saw no decrease in gas mileage, and i thought it was more useful for daily driving. i mean, you are still going to shift about the same number of times, but it revs much quicker. if you decide that you want to go around someone, for example.
Eg_6ness
Mar 10, 2010 09:23 AM
