question about b18c1 compression
Old Apr 20, 2009 | 04:15 PM
amtheiceman's Avatar
Default question about b18c1 compression
does anyone know what the compression on my b18c1 should be, i just bought a cornwell compression tester kit and checked it on my unistall b18c1 and it read about 240 psi on all four cylinders, and i was told the engine had about 110k, i just wanted to know how a healthy b18c1 should read
thanks for any info
Old Apr 20, 2009 | 05:32 PM
99JDMHATCH's Avatar
Default Re: question about b18c1 compression
should be around 200. the rule of thumb is no more then %10 less or more then 200.
Old Apr 20, 2009 | 05:47 PM
i just read that the haynes manual says that
"the cylinder pressure must not exceed 270psi or be any lower than 135psi.
there must not be any variation greater than 28psi between any cylinders."
im guessin this is when the engine is warm. but since the engine is not on the car yet, should the temp have any effect on the test, if so how?
Old Apr 20, 2009 | 06:14 PM
fergy016's Avatar
For a stock b18c1 I would expect to see 200-270 psi on each cylinder doing a compression test on a cold engine. More importantly seeing no more then a 15-20 psi discrepency between cylinders. Instructions on how to do a compression test here at c-speed racing
Old Apr 20, 2009 | 07:05 PM
thanks for all the info...
Old Apr 21, 2009 | 04:11 PM
civicgsr499's Avatar
yeah mine was 235-235-235-238 so urs sounds about right. the guy told me mine had 90k on it but i doubt it. u dont see too many 14 year old usdm motors with that type of mileage... doesnt matter to me too much tho, as long as the compression is good
Old Apr 21, 2009 | 05:46 PM
sounds like i have an ok engine.. for over 100k
Old Apr 22, 2009 | 04:35 AM
yeah i would be happy with it... im guessing its usdm? what yr?
Old Apr 22, 2009 | 06:00 AM
halocore's Avatar
well my compression results came up to be at 150,180,180,154. Could the two of the cylinder be low due to my valves ticking?
Old Apr 22, 2009 | 06:57 AM
fergy016's Avatar
do a valve adjustment directions here @ c-speed racing
then do the compression test again.
Old Apr 23, 2009 | 12:40 PM
its a 95 grs usdm
Old Mar 17, 2012 | 12:15 PM
carlosd68's Avatar
how do you do a compression test on a motor that is not on a car?
Old Mar 17, 2012 | 05:37 PM
Morvpleez's Avatar
My gsr is 215,210,215,215. Original motor. The motor should be warm when you do a compression test. From what I have read a cold motor will show higher numbers. Mine has 231k mls
EG6 Love
Feb 15, 2008 05:06 PM
fsp31
Jan 7, 2005 02:08 PM
itsmebeaner1987
Oct 31, 2004 11:54 AM
FrankEXsteiN
Dec 23, 2002 04:46 AM
VTC_CiViC
Oct 8, 2001 06:11 PM
