I need a definite answer...17 x 8 rims...what offset???
Old Aug 15, 2002 | 06:38 PM
itr157's Avatar
New User
Default I need a definite answer...17 x 8 rims...what offset???
I am looking into getting 17 x 8 Speedy Atix in gunmetal for my prelude...I am lowered on H and R sports and of course i want no rubbing...can someone please give a definite offset to buy...it seems like there is always a different answer...thanks in advance!
Old Aug 15, 2002 | 06:39 PM
itr157's Avatar
New User
Default Re: I need a definite answer...17 x 8 rims...what offset??? (itr157)
oh yea it's a 5th gen...sorry.
Old Aug 16, 2002 | 11:39 AM
itr157's Avatar
New User
Come on nobody knows the answer to this.
Old Aug 16, 2002 | 12:54 PM
aklucsarits's Avatar
New User
I don't think that 8" wide wheels on a Prelude are a good idea with any offset... But to get the effective offset close to stock, it would be around +48mm.
Andrew
Old Aug 16, 2002 | 05:07 PM
ShowSpeed's Avatar
18x8.. use +45 mm
17x8 use the same thing. +45 or +42 is okay.
i had 18x8 +42 before.. and i had 18x8 +45 before also. both works fine.
choose between these tires:
215/35/18 (no lip protection)
215/40/18 (no lip protection)
225/35/18 (good set up)
225/40/18 (nice and big.. the mean look)
Old Aug 16, 2002 | 05:33 PM
98lude's Avatar
Default Re: I need a definite answer...17 x 8 rims...what offset??? (ShowSpeed)
18x8.. use +45 mm
Are you sure 8" rim will work with +42 and no rubbing? I used 17X7 with 40mm before, and it rubbed like hell. In the end, I had to use +43 offset to ensure 7" rim will not rub. 18 or 17" rim doesn't matter in this case, only the width matter.
Think about it, stock is 6.5" with 55mm offset, so with an increase of 1.5", and assuming that you want to increase the rim evenly on both inside and outside with respect to the center, you will be increasing the width at 0.75" on both side. Assuming 1" = 30mm ( bad approximation, but you can do the math yourself), .75" will translate to 22.5mm. decreasing the offset by 10mm will move the rim 12.5 mm to the inside of the car, and 32.5mm towards the fender. If that will fit, then your offset will be +45mm. However, I am really not sure if you can fit 32.5mm more towards the fender; 12.5mm towards the suspension might be alright though. If you want to move it inner towards the suspension, then your offset will have to go even higher, like +48 or something like that. However, there really isn't a lot of space towards the suspension side.
try to stick with 7.5" instead... It will do you much better.
Old Aug 16, 2002 | 05:44 PM
ShowSpeed's Avatar
Default Re: I need a definite answer...17 x 8 rims...what offset??? (98lude)
i agree. stick with 18x7.5 and you'll be safe for sure.
Of course, the tire matters too. 225/40/18 will make you flush with fender. of course.. you have to consider suspension too.
Old Aug 16, 2002 | 10:45 PM
Buckwild's Avatar
I wouldn't get 8" rims since there is no added benefit from it. You're never going to go with tires that can adequately accomodate them. I figure the widest you'll go is 225's on the 8" tires, and you can fit 225's on 7.5's just fine. All you're doing is just getting a heavier rim.
Depending on how low you are, +42mm or higher is good. I currently have that offset on 225/35's and I'm not rubbing at all. But then again, my car isn't slammed (I don't want to deal w/ excessive scraping and camber problems). Ideally, I would get +44mm or higher...and you'll be fine.
thisguyhere
Honda Civic (2001 - 2005)
16
Jun 11, 2009 08:15 AM
zirac50
May 14, 2008 03:13 PM
Nathan007
Apr 18, 2006 10:56 AM
orion840
Nov 3, 2004 07:08 PM
DrewsCrx
Dec 3, 2002 02:38 PM
