Front wheel bearing on 99 integra
Old Apr 20, 2009 | 02:29 PM
9milano9's Avatar
Default Front wheel bearing on 99 integra
i have a slight back in forth motion pushing in on the wheel and pulling back out on the front left wheel of my teg... Im pretty sure its a wheel bearing... Was just curious to how long it will take to replace the wheel bearing?? Im going to take it into school and do it but i need a estimated time...
Old Apr 20, 2009 | 02:51 PM
cerealbox575's Avatar
Default Re: Front wheel bearing on 99 integra
well the way your describing it...i sounds like a tie rod. might be the inner onend those have to be done professionaly. the wheel bearing makes a loud humming noise when driving and gets slower when you slow down.
Old Apr 20, 2009 | 04:26 PM
BlueIntegraBoy's Avatar
If you hold the wheel at 12 and 6 o'clock positions and are able to rock it, wheel bearing is bad. Once you have the knuckle off, changing the bearing is simply pressing the old one out and the new one in.
Old Apr 20, 2009 | 08:18 PM
1tuffbb6's Avatar
Rock it how?
Old Apr 20, 2009 | 08:49 PM
Originally Posted by 1tuffbb6
Rock it how?
If you push the top of the wheel in and the bottom out, and vice versa.
Old Apr 20, 2009 | 08:58 PM
1tuffbb6's Avatar
Very interesting, good info.
Old Apr 21, 2009 | 05:52 PM
9milano9's Avatar
thanks guys. It was a wheel bearing like i said...but i pressed old one out and new one in today at school...inner tie rod was fine...
ZexyAccord
Honda Motorcycles
May 31, 2007 05:27 PM
bus stop
19
Apr 22, 2003 12:18 AM
Takeoff
Feb 23, 2003 11:11 AM
GSxRated
Aug 3, 2002 08:44 AM
