90 crx si lighting problem
Old Apr 20, 2009 | 04:02 AM
xaine's Avatar
Default 90 crx si lighting problem
ok so i got a 90 crx si
the right front blinker and the right front corner lights arent working
i have checked all fuses
i have replaced all bulbs
I have tracked wires , and there is no break any where
What else could it be?
thanks for any help
Old Apr 20, 2009 | 07:40 AM
xalents23's Avatar
Default Re: 90 crx si lighting problem
Did you try checking your turn signal switch. Maybe the contacts are getting worn out.
Old Apr 20, 2009 | 08:10 PM
xaine's Avatar
the rear signal works.
it is only the front right turn signal and running lights
that doesnt work
Old Apr 20, 2009 | 10:18 PM
pushinglikekrazy's Avatar
check if they share a common ground
Old Apr 21, 2009 | 07:37 AM
91-CRX-Si's Avatar
Just throwing this out as a guess......is there a wire harness that could be disconnected from firewall? Like I said just a guess...or like said before check grounds.
Old Apr 21, 2009 | 10:52 AM
xaine's Avatar
this sounds good. maybe that.
anyone else?
Old Apr 27, 2009 | 07:57 PM
xaine's Avatar
well it was a bad ground. made a ground for it.
but also the bulbs were making a bad connection at the plugs
just flipped bulbs , all is good now
misael-crx1986
Mar 4, 2009 12:55 PM
casmello
Nov 28, 2005 07:32 PM
roadhead
May 10, 2005 07:35 PM
131racer
Mar 24, 2004 12:44 PM
crxtreme27
Jun 10, 2003 10:03 PM
