ls tranny with b16 gears?
Old Apr 19, 2009 | 09:24 PM
boostedefhatch's Avatar
Default ls tranny with b16 gears?
ok so i know you can put a ls 5th gear in a b16 tranny, but are the other gear swappable? like if i got a hydro ls trans, could i put a cable b16 gear in it?? this is just me being curios thanks
Old Apr 19, 2009 | 09:33 PM
bodiez's Avatar
Hit the floor!
Default Re: ls tranny with b16 gears?
Im pretty sure you can, but ill let the more informed members give you the 100% sure answer. Also, I think you mean you can put a ls 5th gear in a gsr transmission
Old Apr 19, 2009 | 09:35 PM
thanks, lol no i mean b16 with ls 5th gear, its been done and well know for better mpg and lower rpms at highway speeds, i basically low on cash i see it like a hybrid tranny, ls tranny with b16 gears no clue in hell if it will work just curios
Old Apr 19, 2009 | 09:37 PM
bodiez's Avatar
Hit the floor!
gsr tranny is a b16 transmission. you have gsr or ls. ls has long gears (including the long 5th) and the gsr tranny has quicker gears. so basically you want to put an ls 5th in a gsr.
Old Apr 19, 2009 | 10:32 PM
ryanevansoh's Avatar
im pretty sure you cant take the gears from a cable tranny and put them in a hydro because the thing that holds the coutershaft and mainshaft together is different in the 2 transmissions. one has 2 rods (not sure of name) and the hydro has 3
Old Apr 19, 2009 | 10:49 PM
88_acED6's Avatar
i'm pretty sure a b16 tranny has shorter gears than a gsr
Old Apr 19, 2009 | 10:57 PM
jdm206's Avatar
Im doing the same thing but I'm useing a 93 ls trans and useing the gears from my 91 j1 trannny.
Old Apr 20, 2009 | 01:08 AM
gsr is NOT a b16 trans, b16 has shorter gears than gsr
you are correct
ok, you putting b16 gears in a ls? what i WANT to know is if i can put B16 GEARS in a LS Trans NOT LS gears in B16 i want B16 IN LS TRANS is this possible has it been done
Old Apr 20, 2009 | 05:26 PM
jdm206's Avatar
I'm doing this right now I'm taking all my gears from my j1 b16 tranny, and putting it in my 93 ls trany
Old Apr 20, 2009 | 05:43 PM
88Hatchy's Avatar
As far as I know, the ONLY cable transmission that you can swap hydro gears back and forth is a YS1 case.
Old Apr 20, 2009 | 06:28 PM
REALLY!!!!?? what made you want to do it? do you have the same idea as me?
well there cable b16 tranny that he has, and i want to put the internals in a hydro ls trans...
Old Apr 20, 2009 | 06:31 PM
88Hatchy's Avatar
Unless it is a YS1 transmission from an Integra XSi (the only B16 that came with a YS1), then it WILL NOT work.
Old Apr 20, 2009 | 07:04 PM
hmm it is, would it be a reliable trans?
Old Apr 21, 2009 | 10:19 AM
kyleb18t's Avatar
i was reading and thought id offer a different route ls trans with mfactory 4.9 final.
this will sit between 98 type r and xsi trans mission and ls trans cheaper to get
Old Apr 21, 2009 | 11:48 AM
88Hatchy's Avatar
Huh? Where is the confusion?
It will either all bolt together and work, or it won't. I have a YS1 case with DC GSR gears and it works fine.
Old Apr 30, 2009 | 10:25 AM
EG6Boy702's Avatar
Im also doing the same project, i have a b17a ys1 transmission, but its a cable transmission so i want to put the b17 1-4th gear in the LS hydro transmission but keep the ls 5th gear.. is this all possible you think?
Old Oct 17, 2009 | 12:10 PM
tlmg21700's Avatar
i have a gsr with b16 gears right now and the b16 gears are defenitly diffrent then the gsr ones
Old Jun 27, 2010 | 08:33 AM
209-559EG6's Avatar
Sorry to change the subject but I had a question
I have a B16 tranny Hydro that the gears are bad
can I used the B18 Ls tranny Hydro gears to be swap to
the B16 tranny???
Old Jun 27, 2010 | 11:32 AM
Deetz's Avatar
Crazy Honda Guy
the B16 tranny???
yes, all hyro tranny's have interchangable parts. Personally, i don't think it's worth the time and money!!! Just get another tranny
If you are going for a complete rebuild, contact gear speed, they would be a top choice in your rebuild regardless of what setup you would like
Old Jun 27, 2010 | 08:41 PM
209-559EG6's Avatar
K...
But If my gears on the B16 3rd gear is bad can i put a Ls 3rd gear?
both are hydro
Old Jun 27, 2010 | 10:04 PM
Deetz's Avatar
Crazy Honda Guy
K...
both are hydro
that would be stupid....do not do that!
You don't want a short 1st, 2nd, then this TALL 3rd gear, then back to a short 4th
Old Jun 28, 2010 | 01:20 PM
209-559EG6's Avatar
okay.. but how about if I leaved 1st, 2nd, b16 gears and 3rd, 4th, 5th Ls
on the b16 tranny....will that be better
Im saying that cuz i got both trannys
Old Jun 28, 2010 | 01:30 PM
209-559EG6's Avatar
Also if I do that am I going to need the Ls ratios or b16 from 3rd 4th and 5th since its from the LS
igorka_91
Transmission & Drivetrain
Nov 7, 2009 11:23 PM
BIG T
Aug 24, 2007 05:49 PM
ErikDaGenErik
Jan 15, 2007 06:54 AM
Lshatchy91
Jun 30, 2004 11:23 PM
92bluesi
13
Feb 2, 2004 04:09 PM
