Help me Weld billet T6061 Intake Manfiold
Im having some issues on welding the runners to the D Style Plenum. Im using Green Tungsten And having issues on getting the Plenum to form a spot on it so i can weld a gap from the runner to the Plenum.
Also what do you guys use to clean aluminum before welding?
What AMP should i use?
What Size Tungsten? Anything else i should know?
when I weld aluminum, Ill hold my arc, or go back and forth from piece to piece untill the surface of the alum looks like its luquidy, then ill add my filler. after that I dont even really weave just go and dab dab dab. youll see what I mean. like It said you wont fuse two pieces together first like steel.
what amps should i use?
Also how should i prep the tungsten, I always feel like im doing it wrong with aluminum
Sometimes i feel like the welds get contaminated because it starts bubbling and
tungsten just grind length wise as normal to a shrap point such as SS then just lightly stab the wheel to break the sharp part off, then grab a piece of scrap and weld a short bead so you don't include the tungsten fragments on the **** that includes something. i just do that so i see a ball which is probably a bad habbit but w/e.
the bubbling is the metal starting to get hot keep going until you see a shiny puddle
Use a 1/8" diameter pure (green tungsten) and sharpen it to a 45 degree bevel or so. Get a block aluminum and form the ball on the end of the tungsten so it's at least the same diameter as the tungsten.
Pre-heat the aluminum if possible (oven) or with your torch.
I suspect you simply aren't generating enough heat. Try 250 amps and give it the wood.
as always prep your metal.
stainless wire brush is all i use for alum prep.
when i start a tack weld, i will crank my welder as high as it goes (180) and pump the pedal probably between 150 and 180 to heat up the material... add a drop of filler to start a puddle and keep pumping until it flattens out across the gap. don't know why, but for tacking, i find this works better. once the puddle is started, then just a steady heat control to match the desired bead size.
92civichatch1
12
Mar 24, 2006 09:43 AM
keithv
Jun 14, 2001 06:44 PM
