B-series starters, interchangable?
Old Apr 19, 2009 | 01:15 PM
vtec8200's Avatar
Default B-series starters, interchangable?
I got a really good deal, 80$ for a rebuilt B-series starter and alternator. I have a 1992 integra Ls and the starter that was on it looks different than the one I bought, however it bolts right up. The conections are not exactly at the same place though.
My question is, even if its from another B-series, and it looks different, since it bolts up to the factory bolt locations, it should work right? Second question, there should only be 2 wires on the starter right? The one from the battery and the little flat clip? I was wondering since there is another bolt hole on both starters and I was wondering if it was needed a ground or something.
thanks!
Old Apr 19, 2009 | 01:26 PM
vtec8200's Avatar
Default Re: B-series starters, interchangable?
well I tried to start the car and when I did, there was this loud repetitive tic sound and the lights on my cluster where flashing at the same time...
Old Apr 19, 2009 | 01:27 PM
DonF's Avatar
thanks!
Does the car start? DOH. Actually the dealer has the "correct" starter. Just so I know, why do all the E-bay and i got this from my "pal" people ask this question AFTER they buy cheap crap.
Old Apr 19, 2009 | 01:39 PM
vtec8200's Avatar
My starter went out on me today, and when I swapped my engine last week, the alternator was not good, and then I changed it yesterday for a used one, still not good. I need the car for tomorrow for work, all junkyards are closed because its sunday, so are autoparts stores. I got this deal really quick today of two rebuilt parts and I am working on the car now. I took a chance by buying it and installing it, and now I seem to have an electrical problem, like if I forgot to put some ground on it (wasn't any on the old starter).
Should have asked first, but I bought the starter and alternator 40 mins ago and the guy wasnt available later.
Old Apr 19, 2009 | 02:09 PM
vtec8200's Avatar
well since my battery is dead because of my bad alternator I put another one (that is almost dead too) and the car cranked 2-3 times before I got no current so I guess the starter DOES work! I also added a ground from the top of the starter (where there was an empty bolt hole) to the chassis, I don't know if that made the difference.
Old May 6, 2009 | 08:46 PM
mattuk180586's Avatar
I'm needing to know the same thing. I just bought a starter for $15 off a B20B manual engine and I'm needing it to work for my B18C1 engine.
BIGGMIKEE
Texas -OK -LA (Sales)
Nov 4, 2010 03:08 PM
T3KNiQe
Nov 22, 2008 01:51 PM
Miknow
Nov 7, 2005 09:59 PM
