how to realign the hood?
Old Apr 19, 2009 | 08:23 AM
949's Avatar
949
Default how to realign the hood?
i had taken off the hood for some mods and when i reinstalled it doesnt unlatch like it used to.
i tried to put it to where the paint was aligned but it still does unlatch perfectly.
is there a trick or a method to adjusting it?
Old Apr 19, 2009 | 08:31 AM
radex7's Avatar
Default Re: how to realign the hood?
What do you mean by unlatch perfectly? Does the release cable work as it should? Is there a spring action left in a latch? Mine was caked with grime and totally stuck. So I would recommend cleaning it well first. And you can adjust it by tightnening/loosening the main pin enclosed by a spring. Flat screwdriver will work.
Old Apr 19, 2009 | 08:13 PM
949's Avatar
949
i had unscrewed it from the two rear hindges.
when i pull the level in the car it pops up but it kinda snags.
lever works just fine.
it worked great before i took off the whole hood for some engine mods.
not sure on how to realign it.
Old Apr 19, 2009 | 10:03 PM
88_acED6's Avatar
loosen all 4 bolts move hood tighten
repeat if needed
racingcrx
Jun 13, 2010 08:24 PM
SlowDown
Apr 10, 2007 08:08 AM
motormike40
Aug 10, 2006 06:33 AM
GetCaughtDead
Oct 25, 2004 05:24 PM
cannan
Dec 27, 2003 03:58 PM
