need help installing driver door
Old Apr 18, 2009 | 11:54 PM
El_Jdm_Junky's Avatar
New User
Post need help installing driver door
my driver door was pulled out like someone had try to brake in to it..i bought a new one i just dont know if its a bitch to put on..does anyone have pics on how to take one door off and put another one on.
Old Apr 19, 2009 | 12:39 AM
meandino's Avatar
Default Re: need help installing driver door
it shouldn't be to hard. I would remove the fender, take the panel off, disconect/feed the wire harness out, and take the pin out from the door checker. you could probably mark the hing for better alignment when installing. I found it easier to close the door when removing the bolts.
Old Apr 19, 2009 | 12:53 AM
civic_jones's Avatar
yeah man its a snap, remove the front fender and you can get to the bolts holding the hinges, undo those and the speaker wiring and the door comes right off, just reverse the process for putting the new door on, as stated above marking the hinges makes aligning the new door a whole lot easier.
Old Apr 19, 2009 | 01:28 AM
New User
thanks..
Old Apr 19, 2009 | 07:46 AM
~sp33~'s Avatar
EFB055
I didn't have to remove my fender.
bg-33p
Mar 26, 2007 10:27 AM
fackyou
Aug 25, 2006 10:03 AM
Lude@Heart
11
Jul 27, 2006 11:19 PM
REVS-2-9K
Sep 2, 2004 02:16 PM
