Idle bouncing under no load
Old Apr 18, 2009 | 07:22 PM
04yfz's Avatar
Default Idle bouncing under no load
So I cleaned my IACV and FIV and still have a problem with the idle. However when I put the car into gear(automatic trans) and turn the A/c on, it will be fine, with the a/c off the idle will even surge in gear. What could be the cause of this? Too high base idle? Any help would be appreaciated. It is a 96 accord 4 cylinder non vtech.
Thanks,
Pat
Old Apr 18, 2009 | 09:11 PM
PTVDesign's Avatar
Default Re: Idle bouncing under no load
1. shutdown a/c
2. disconect IACV
3. run engine, rpm must be ~550 rpm
3.a. if rpm is not 550, shutdown engine and adjust with #1 http://bayimg.com/kApnIaabB
4. connect IACV
5. reset ECU
6. start engine
and 10 minut wait, don't tuch throttle
Michael2595
Feb 4, 2012 10:13 PM
kUrb3d
Aug 16, 2010 11:20 AM
ic89
Oct 14, 2006 02:51 PM
carblegal
Dec 25, 2004 09:51 PM
phill
Sep 9, 2004 08:01 AM
